Product
Brand
Dell M900HD WXGA DLP 900 Lumens LED Projector
Quicklinx: 973HWS00 Mfr#: 210-ABJN
Bring your own projector and present with confidence using a portable, easy-to-use projector featuring Intel Wireless Display (WiDi) and Miracast.
Dell Mobile Projector M900HD - DLP projector - portable - WiDi / 802.11a/b/g/n wireless / Miracast Wi-Fi Display
DLP projector - High Definition 720p
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
900 ANSI lumens
Contrast Ratio
700:1 / 10000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
LED
Bulb life cycle
Up to 30000 hour(s)
Video Input
Intel Wireless Display (WiDi) / IEEE 802.11a/b/g/n wireless / Miracast Wi-Fi Display - MPEG-4, AVI, MJPEG, ASF, WMV, MOV, MKV
Supported Memory Cards
SD Memory Card
Video Modes
480p, 720p, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
142 Watt
23.2 cm x 16.4 cm x 4.3 cm
1.59 kg
1 year warranty
DLP projector - HD 720p
Built-in Devices
Speaker
802.11a/b/g/n
Projector
Microdisplay
DarkChip 3
Brightness
900 ANSI lumens
Contrast Ratio
Image Size
76 cm - 203 cm
Projection Distance
0.91 m - 2.4 m
Throw Ratio
1.4:1
Uniformity
85 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb type
LED
Bulb life cycle
Up to 30000 hour(s)
Controls & Adjustments
Keystone correction
Built-in 2 GB flash memory, High-bandwidth Digital Content Protection System (HDCP), MobiShow technology, 16:10 aspect ratio support, Mercury-free illumination technology, upgradable firmware, Digital Zoom
Lens
Focus Type
Manual
Lens Aperture
F/1.5
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Video Interfaces
HDMI, USB
Video Modes
SD Memory Card
Digital Video Format
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, IEEE 802.11a, IEEE 802.11n, WiDi, Miracast
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
3 Watt
Speakers
1 x mixed channel
Expansion Slots
1 x SD Memory Card
1 x HDMI - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A
Carrying case, dust cover, wireless remote control
1 x USB cable - 1.2 m
Security Features
Security lock slot (cable lock sold separately), password protection
Nominal Voltage
142 Watt
Power Consumption Stand by
0.5 Watt
23.2 cm
16.4 cm
4.3 cm
1.59 kg
Limited warranty - lamp - 1 year , Limited warranty - 1 year
5 °C
35 °C
0 - 80%
Sound Emission
36 dBA
34 dBA
973H C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
973H C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.02
973H C2G 5m Select High Speed HDMI with Ethernet In Stock £16.55
973H C2G 10m Select High Speed HDMI with Ethernet In Stock £32.25
973H C2G 15m Select High Speed HDMI with Ethernet In Stock £43.69
973H C2G Pro HDMI to VGA Converter In Stock £49.56
