Dell LED U2412M Dell Monitor
Quicklinx: DNWFWS00 Mfr#: 210-AGYR
Enjoy widescreen performance, any way you want it. With a 24" 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style.
Dell UltraSharp U2412M - LED monitor - 24"
LED-backlit LCD monitor - 24"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 82% (CIE 1976)
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
55.6 cm x 18.03 cm x 39.85 cm
5.73 kg
Environmental Standards
ENERGY STAR Qualified
Carbon Footprint
522 kg carbon emissions
Plug and Play, DDC/CI, EDID compatible
3-year warranty
Bundled Services
3 years Advanced Exchange Service
Display Type
Diagonal Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
50 - 61 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 10000K
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
LED edgelight system, PowerNap, Dynamic Dimming, stand lock, Energy Saver, Transition Minimised Differential Signaling (TMDS) technology
55.6 cm x 18.03 cm x 39.85 cm - with stand
5.73 kg
VGA , DVI-D , DisplayPort , USB 2.0 upstream (Type B) , 4 x USB 2.0 downstream (Type A)
Mechanical
Tilt Angle
-4/+21
Swivel Angle
90
Rotation Angle
90
Height Adjustment
115 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Dell Energy Smart, LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, Dell Soundbar mounting slots
Stand
1 x DVI cable , 1 x VGA cable - VGA to VGA , 1 x USB cable - USB Type A to B
Mounting Kit
Optional
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
29 Watt
Power Consumption (Off Mode)
0.5 Watt
Included Software
Drivers & Utilities, PowerNap
Dimensions & Weight Details
Without stand - width: 55.6 cm - depth: 6.49 cm - height: 36.16 cm - weight: 3.97 kg , With stand - width: 55.6 cm - depth: 18.03 cm - height: 39.85 cm - weight: 5.73 kg
Sustainability Information
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
90
Manufacturing (kg CO2e)
330
Logistics (kg CO2e)
45
Use (kg CO2e)
144
EOL (kg CO2e)
3
Total Carbon w/o Use Phase (kg CO2e)
378
PAIA Version
9/5/2018
Limited warranty - 3 years
Bundled Services
10 - 80% (non-condensing)
