The small 15" mainstream business-class notebook lets you get to work faster than ever thanks to its scalable features, powerful performance and ExpressCharge.
Connect anywhere
Seamlessly work on the go thanks to optional mobile broadband supporting speeds up to 450 Mbps. -
Travel light
The Latitude 5500 is more mobile and portable than ever, with an improved design that's thin and modern. -
Ultimate views
The display is packed with features designed to keep you focused on your work, like the four-sided narrow bezel and antiglare screen.
- Dell Latitude 5500 - 15.6" - Intel Core i5 - 8265U - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Processor
- Intel Core i5 (8th Gen) - 8265U / 1.6 GHz, up to 3.9 GHz / 6 MB Cache
- Memory
- 8 GB DDR4
- Storage
- 256 GB SSD - NVMe
- Display
- 15.6" WLED 1920 x 1080 / Full HD @ 60 Hz
- Graphics
- Intel UHD Graphics 620
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
- Black
- 35.91 cm x 23.625 cm x 2.2 cm
- 1.82 kg
- Pricing Type
- Build To Stock (BTS)
- Limited warranty - 1 year - on-site
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
- 15.6"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
- Anti-glare, Wide Viewing Angle
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- 78.6 degrees, RGB camera
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3204
- High Definition Audio
- Audio Features
- Output: MaxxAudio Pro
Input
- Keyboard, touchpad
- Numeric Keypad
- Multi-touch touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Technology
- 4-cell Lithium Ion
- Capacity
- 68 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V, 3.34 A
Connections & Expansion
- Interfaces Details
- 3 x USB 3.1 Gen 1 , LAN , HDMI , Headphone/microphone combo jack , USB-C 3.1 Gen 2 (supports DisplayPort Alt Mode)
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Microsoft Office (Trial)
- Black
- Security
- ExpressCharge
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- Pricing Type
- 1.82 kg
Sustainability Information
- TCO Certified
- 0 °C
- 35 °C
- 10 - 80% (non-condensing)
- Shock Tolerance (operating)
- 105 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 40 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.26 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.37 g @ RMS (random)
Dell Slim DW316 USB External DVD Drive | In Stock | £35.33 |
Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 | In Stock | £15.04 |
APC Smart-UPS SMC1000IC - UPS - AC 220/230/240 V - 600 Watt | In Stock | £435.07 |
APC BACK-UPS BE650G2-UK 650VA 230V | In Stock | £106.54 |
APC BACK-UPS BE850G2-UK 850VA 230V USB | In Stock | £119.23 |
Dell E2020H 20" 1600 x 900 5ms VGA LED monitor | In Stock | £54.51 |
