Adjustable voltage sensitivity
Provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications. -
Audible alarms
Provides notification of changing utility power and UPS power conditions -
Automatic self-test
Periodic battery self-test ensures early detection of a battery that needs to be replaced. -
Battery charging indicator
Lets you know when your battery is charging and when it is fully charged. -
Battery failure notification
Provides early-warning fault analysis on batteries enabling timely preventive maintenance -
Battery-protected and surge-only outlets
Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment -
Building Wiring Fault Indicator
This LED informs users of potentially dangerous wiring problems in the wall circuit. -
Cold-start capable
Provides temporary battery power when the utility power is out. -
Dataline surge protection
Provides protection of connected equipment from power surges on the data lines. -
Disconnected battery notification
Warns when a battery is not available to provide backup power. -
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced -
Safety-agency approved
Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment. -
Simple battery replacement
Increases UPS availability by allowing quick, easy battery replacement. -
USB connection
Use your PC to access additional power protection and management features for your UPS via a USB Port. -
User-replaceable batteries
Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
- APC Back-UPS BE650G2-UK - UPS - 400 watt - 650 VA
- UPS - external
- 4 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Power Capacity
- 400 watt / 650 VA
- Input Connectors
- 1 x power BS 1363A
- Output connectors
- 6 x power (UPS and surge) , 2 x power (surge) , 1 x 4 pin USB Type A 2.4 A
- Battery
- Lead Acid
- Batteries Qty
- 1
- Run Time (Up To)
- 2.6 min at full load
- Black
- 13 cm x 36.5 cm x 12 cm
- 3-year warranty
- UPS - external
- Black
- Localisation
- United Kingdom
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 180 - 266 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 47 - 63 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V 50/60 Hz
- Power Capacity
- 400 watt / 650 VA
- Dataline Surge Protection
- Network - RJ-45
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Surge Energy Rating
- 310 joules
- Circuit Protection
- Circuit breaker
- Efficiency
- 80%
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 56.2 min at 50 Watts , 26 min at 100 Watts , 10.4 min at 200 Watts , 5.2 min at 300 Watts , 2.6 min at 400 Watts
- Recharge Time
- 16 hours
- Transfer Time
- 6 ms
- Maintenance free, sealed
- Cables Included
- Power cable 1.83 m
- Overload protection, audible alarm
- IP20
- Software Included
- APC PowerChute Personal Edition
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- 13 cm
- 36.5 cm
- 12 cm
- 4 kg
- Shipping Width
- 18.6 cm
- Shipping Depth
- 44.1 cm
- Shipping Height
- 19 cm
- Shipping Weight
- 4.5 kg
APC Replacement Battery Cartridge #110 | In Stock | £57.13 |
