Dell Latitude 3510 15.6" i5 10210U 8GB 1TB / Win 10 Pro 64-bit
Quicklinx: FYR7WS00 Mfr#: H64CF
  • Core i5
  • IEEE 802.11n
UK/BTS/Lati 3510/Core i5-10210U/8GB/1TB/15.6" HD/Intel UHD/Cam & Mic/WLAN + BT/Backlit Kb/3 Cell/W10Pro/1Y Basic Onsite.
Dell Latitude 3510 - 15.6" - Intel Core i5 - 10210U - 8 GB RAM - 1 TB HDD
Notebook
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i5 (10th Gen) - 10210U / 1.6 GHz, up to 4.2 GHz / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
1 TB HDD / 5400 rpm
Display
15.6" 1366 x 768 / HD @ 60 Hz - 100 ppi
Graphics
Intel UHD Graphics
Keyboard Backlight
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac Wave 2/ax, Bluetooth 5.1, Gigabit Ethernet
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
Grey
36.14 cm x 24.785 cm x 1.797 cm
1.91 kg
Pricing Type
Build To Stock (BTS)
Bundled Services
1 Year Basic Onsite
Notebook
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Intel Core i5 (10th Gen) 10210U / 1.6 GHz
Max Turbo Speed
4.2 GHz
Number of Cores
Quad-Core
Cache
6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM - non-ECC
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
1 TB HDD SATA / 5400 rpm
Display
15.6"
Resolution
1366 x 768 (HD)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
100
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Colour Gamut
45% NTSC
Anti-glare, 25 ms response rate, 0.252 mm pixel pitch, ±40° horizontal viewing angle, +10/-30 vertical viewing angle
Audio & Video
Graphics Processor
Intel UHD Graphics
Memory Allocation Technology
Shared Video Memory (UMA)
Camera
Yes - HD
Resolution
0.92 Megapixel
Image Sensor Type
CMOS
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
RGB camera, 87 degrees
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3204
High Definition Audio
Input
Keyboard, touchpad
Keyboard Backlight
Numeric Keypad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 201
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111H
3-cell
40 Wh
AC Adapter
Input
Output
65 Watt, 19.5 V, 3.34 A
Connections & Expansion
Interfaces Details
HDMI , USB-C 3.2 Gen 1 (supports DisplayPort Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (PowerShare) , USB 3.2 Gen 1 , USB 2.0 , LAN , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (Trial)
Grey
Security
ExpressCharge
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter
Pricing Type
1.91 kg
Sustainability Information
TCO Certified
Bundled Services
1 Year Basic Onsite
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
FYR7 Dell Upgrade from 1Y Basic Onsite to 3Y Basic Onsite - Extended Service Agreement In Stock £40.11
Other bundles (6)
FYR7 Dell Slim DW316 USB External DVD Drive In Stock £36.19
FYR7 Dell MS116 Mouse Optical Wired USB Black For Lattitude In Stock £7.34
FYR7 Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 In Stock £11.98
FYR7 APC Smart-UPS SMC1000IC - UPS - AC 220/230/240 V - 600 Watt In Stock £437.20
FYR7 APC BACK-UPS BE650G2-UK 650VA 230V In Stock £105.55
FYR7 APC BACK-UPS BE850G2-UK 850VA 230V USB In Stock £118.16
