Intelligent and efficient network power protection from entry level to scaleable runtime. Ideal UPS for servers, point-of-sale, routers, switches, hubs and other network devices.
Smart-UPS are trusted by millions of IT professionals throughout the world to protect equipment and critical data from costly interruptions by supplying reliable, network-grade power reliably and efficiently.
SmartConnect
Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services. -
Software package
SmartConnect software for remote power monitoring feature availability varies by terms of use -
Communication port support
SmartConnect Ethernet port for cloud monitoring feature availability varies by terms of use -
High online efficiency
Reduces utility costs, generates less heat. -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
Pure sine wave output on battery
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. -
LCD Status Display
Provides key UPS status at a glance. Multiple status indicators with load and battery bar graphs. -
Cold-start capable
Provides temporary battery power when the utility power is out. -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature.
- APC Smart-UPS SMC1000IC - UPS - 600 Watt - 1000 VA
- UPS - external
- 17.25 kg
- Input Voltage
- AC 220/230/240 V
- Output Voltage
- AC 230 V
- Power Capacity
- 600 Watt / 1000 VA
- Input Connectors
- 1 x power IEC 60320 C20
- Output connectors
- 8 x power IEC 60320 C13
- Battery
- Lead Acid
- Batteries Qty
- 1
- Run Time (Up To)
- 5 min at full load
- Networking
- USB
- Black
- 21.9 cm x 17.1 cm x 43.9 cm
- UPS - external
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 220/230/240 V
- Input Voltage Range
- AC 180 - 286 V
- Input Voltage Range (Adjustable)
- AC 170 - 300 V
- Frequency Provided
- 47 - 63 Hz
- Frequency Required
- 50/60 Hz ± 3%
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V 47 - 63 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Energy Rating
- 693 Joules
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 5 min at full load , 14 min at half load
- Remote Management Interface
- USB
- 1 x management - RJ-45 , 1 x USB - 4 pin USB Type A
- Audible alarm, LCD display
- C-Tick, GOST, VDE
- Software Included
- APC PowerChute Business Edition
- 21.9 cm
- 17.1 cm
- 43.9 cm
- 17.25 kg
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £200.61 |
APC 1U Vertical Cable Organiser | In Stock | £121.88 |
APC 1U Horizontal Cable Organiser | In Stock | £54.48 |
APC - rack cable guide - 1U | In Stock | £50.76 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £296.92 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £318.21 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £285.99 |
APC Cable Managers (Qty 10) | In Stock | £35.09 |
APC 2G Power distribution strip | In Stock | £642.16 |
APC Rack PDU 2G METERED ZEROU | In Stock | £684.85 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £977.90 |
APC 19" Rack LCD Console | In Stock | £1,376.96 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £80.70 |
APC 1U Blanking Panel Kit | In Stock | £34.48 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £55.76 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £47.97 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,681.62 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £68.86 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £635.18 |
APC Replacement Battery Cartridge #142 | In Stock | £118.58 |
APC Metered Rack PDU | In Stock | £841.26 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £731.01 |
APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U | In Stock | £263.05 |
APC 1 Year Extended Warranty 2015-4037 | In Stock | £61.77 |
APC Service Pack 3 Year Warranty Extension | In Stock | £113.44 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £60.92 |
APC Switched PDU 10A 0U C13x16 | In Stock | £1,123.97 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £657.20 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,250.31 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £158.31 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £81.35 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £467.37 |
