View your applications, spreadsheets and more with incredible clarity. Optimize eye comfort and reduce harmful blue light emissions with ComfortView and a flicker free screen. See consistent colors across an ultrawide viewing angle. Easily access buttons for power, brightness, contrast and customizable preset modes on the monitor's front panel. Work comfortably by tilting the monitor 5° forward or 21° backward. The monitor is compatible with most legacy and current PCs via VGA and DisplayPort connectivity.
Maximize workplace productivity with a monitor designed to meet your business needs
View your applications, spreadsheets and more with incredible clarity. Optimize eye comfort and reduce harmful blue light emissions with ComfortView and a flicker free screen. See consistent colors across an ultrawide viewing angle. -
Create a workspace that fits your desired specifications
- Dell E2417H - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.275 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC (CIE 1931), 87% NTSC (CIE 1976)
- Input Connectors
- VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 56.26 cm x 17.99 cm x 42.51 cm
- 3.97 kg
- Carbon Footprint
- 496 kg carbon emissions
- Plug and Play, DDC/CI, RoHS, EDID compatible
- Limited lifetime warranty
- Bundled Services
- 3 years Advanced Exchange Service
- Designed For
- Latitude 7400 2-in-1
- Display Type
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.275 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- LED edgelight system, Flicker Free technology, BFR/PVC-free, Mercury free, arsenic-free glass, Dell ComfortView
- Black
- 56.26 cm x 17.99 cm x 42.51 cm - with stand
- 3.97 kg
- DisplayPort , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, Dell Soundbar mounting slots
- Included Accessories
- VESA screw cover
- Cables Included
- 1 x DisplayPort cable
- Input Voltage
- Power Consumption Stand by
- 22 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 56.26 cm - depth: 17.99 cm - height: 42.51 cm - weight: 3.97 kg , Without stand - width: 56.26 cm - depth: 5.35 cm - height: 33.31 cm - weight: 3.28 kg
Sustainability Information
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 93
- Manufacturing (kg CO2e)
- 321
- Logistics (kg CO2e)
- 37
- Use (kg CO2e)
- 136
- EOL (kg CO2e)
- 2
- Total Carbon w/o Use Phase (kg CO2e)
- 360
- PAIA Version
- 9/5/2018
- Limited warranty - 3 years
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
- Designed For
- Dell Latitude 7400 2-in-1
