Dell Dock with 130W AC adapter WD15 USB C Interface 1 x Mini Disp
Quicklinx: C5XKWS00 Mfr#: 452-BCDJ
The Dell Dock-130W provides a common docking experience for both Dell and non-Dell platforms via Display Port over USB Type-CM, ensuring a reliable connection and crisp display. The dock connects with a single cable, freeing up space on your desk and in your workspace with the added ability to mount behind a monitor or on your desk. Great for presentations, the small and compact Dell Dock enables fast, efficient connectivity to multiple displays and all your everyday peripherals through one convenient cable.
  • Single cable connectivity
    Featuring a powerful DisplayPort over USB Type-C cable, with the Dell Dock-130W you can quickly connect your laptop or tablet to a single data and power source. You'll also enjoy an easy, reliable connection from your laptop or tablet to dual FHD displays or a single 2560 x 1600 display, and all your essential peripherals. It also supports maximum display resolution of 4K at 30 Hz.
  • Small footprint and big flexibility
    The Dell Dock-130W is small in size - just 6.1 x 4.3 x. 83 inches (155 x 109 x 21 mm) - and has one single cable. Place it anywhere you want to work - in your traditional office workspace, a hot desk or a conference room - even if space is limited.
  • One dock for all
    The Dell Dock-130W is compatible with select Dell laptops, workstations, tablets and many compatible non-Dell devices with USB-Type C connectivity. Easily connect to displays, a mouse, keyboard and audio devices through the Dell Dock-130W from your compatible system of choice.
  • Connect for collaboration
    Grab your laptop and head to the next meeting where you, and your co-workers, will be able to quickly connect to the Dell Dock-130W and share your latest PowerPoint presentation through a connected display screen or projector.
  • Enhanced video performance
    USB Type-C connectivity is the latest and extremely reliable technology for video performance. Your display will be crisp and clear.
Dell Dock WD15 - docking station - USB-C - VGA, HDMI, Mini DP - 1GbE
Docking station
Docking Interface
USB-C
Video Interfaces
VGA, HDMI, Mini DP
15.5 cm x 10.9 cm x 2.11 cm
422 g
United Kingdom
Gigabit Ethernet
Power adapter 130 Watt Power Provided
Alienware 13 R2; Latitude 5175 2-in-1, 5179, 5280, 5480, 5580, 7275, 7280, 7370, 7480; Venue 10 Pro (5056), 8 Pro (5855); XPS 12 9250, 13 9350, 15 9550 (130 Watt)
Docking station
15.5 cm
10.9 cm
2.11 cm
422 g
United Kingdom
Gigabit Ethernet
2 x USB 2.0 - 4 pin USB Type A , 3 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - Mini DisplayPort - Mini DisplayPort , 1 x network - Ethernet 1000 - RJ-45 , 1 x headset - output - mini-phone 3.5 mm , 1 x audio - output - mini-phone 3.5 mm , 1 x video - VGA - 15 pin D-Sub (DB-15)
1 x DisplayPort / USB-C cable - 80 cm , 1 x SuperSpeed USB-C cable - 80 cm
Security Slot Type
Kensington security slot
Power adapter
Power Provided
130 Watt
Red Hat Linux 7.2, Microsoft Windows 7 / 8 / 8.1 / 10
Alienware 13 R2 , Dell Latitude 5175 2-in-1, 5179, 5280, 5480, 5580, 7275, 7280, 7370, 7480 , Dell Venue 10 Pro (5056), 8 Pro (5855) , Dell XPS 12 9250, 13 9350, 15 9550 (130 Watt)
