Always on the go? No more worries about running out of battery power! You can power your laptop with this 6-cell Lithium-ion battery from Dell. With a capacity of up to 65 WHr, the battery lets your laptop work seamlessly when you are on the move.
- Dell Primary Battery - laptop battery - Li-Ion - 65 Wh
- Laptop battery
- 326 g
- Battery
- Lithium Ion 6-cell - 65 Wh
- 20.8 cm x 4.8 cm x 2 cm
- 1-year warranty
- Designed For
- Latitude E6440, E6540; Precision M2800
- Laptop battery
- Technology
- 6-cell Lithium Ion
- Capacity
- 65 Wh
- Limited warranty - 1 year
- 20.8 cm
- 4.8 cm
- 2 cm
- 326 g
- Designed For
- Dell Latitude E6440, E6540 , Dell Precision M2800
