Dell 8GB Certified Memory Module - 2RX8 SODIMM 2400 MHz
Quicklinx: CWYDWS00 Mfr#: A9210967
Supercharge your Dell system with a Dell Memory upgrade engineered, tested and customized for your system. Adding more memory revs to your system's engine and allows you to release its full potential when working with 3D imaging, multimedia, and other memory intensive applications.
Dell - DDR4 - module - 8 GB - SO-DIMM 260-pin - 2400 MHz / PC4-19200 - unbuffered
Memory module
8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Single rank, unbuffered
Voltage
1.2 V
DELL A9210967, DELL SNPMKYF9C/8G
8 GB
Upgrade Type
System specific
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Non-ECC
Module Configuration
1024 x 64
Chips Organization
X8
Voltage
1.2 V
