Dell 23" Monitor P2317H Black UK 210-AJEM VGA HDMI DP VGA
Quicklinx: CDS9WS00 Mfr#: P2317H
More productive than ever. This Dell monitor brings an amazing level of productivity to the work place without sacrificing comfort and convenience.
  • Purposefully designed for comfort and convenience
    With a full range of adjustable features, slim borders and multiple connectivity ports.
  • Enhanced viewing experience
    Dell ComfortView and flicker-free feature make work less strenuous when viewing vividly clear visuals across an ultrawide viewing angle.
  • Reliable and responsible
    Get complete piece of mind with Premium Panel Guarantee, Advanced Exchange Service and an eco-friendly design.
  • A more seamless workflow
    Slim borders create a smoother and less obstructed visual experience when working across multiple monitors.
  • Versatility you can count on
    Enjoy full adjustability to pivot, tilt, adjust the height, and swivel your monitor to your exact preference.
  • More ways to stay connected
    Multiple connectivity ports on the bottom and side of the monitor allow you to easily connect to various devices.
Dell P2317H - LED monitor - Full HD (1080p) - 23"
LED-backlit LCD monitor - 23"
Energy Class
Class A+
Energy Consumption per Year
22 kWh
Power Consumption (On mode)
15 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 4000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931), 82% NTSC (CIE 1976)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
53.2 cm x 18 cm x 35.71 cm
5.16 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Carbon Footprint
493 kg carbon emissions
EMC, DDC/CI, RoHS
3-year warranty
Bundled Services
3 years Advanced Exchange Service
Display Type
Energy Class
Class A+
22 kWh
Diagonal Size
23"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.265 mm
Pixel Per Inch
96
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
Ultra wide viewing angle, LED edgelight system, stand lock, Flicker Free technology, BFR/PVC-free, Energy Gauge, Mercury free, arsenic-free glass, Dell ComfortView
53.2 cm x 18 cm x 35.71 cm - with stand
5.16 kg
HDMI , DisplayPort , VGA , USB 3.0 upstream , 2 x USB 2.0 downstream , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, anti-theft protection, Dell Soundbar mounting slots
1 x VGA cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
EMC, DDC/CI, RoHS
Security Slot Type
Kensington security slot
Input Voltage
15 W
Power Consumption (Typical)
18 watt
Power Consumption Stand by
0.3 watt
Power Consumption Sleep
0.3 watt
Power Consumption (Off Mode)
0.3 watt
Included Software
Dell Display Manager
Dimensions & Weight Details
With stand - width: 53.2 cm - depth: 18 cm - height: 35.71 cm - weight: 5.16 kg , Without stand - width: 53.2 cm - depth: 5.03 cm - height: 31.59 cm - weight: 3.06 kg
Shipping Weight
7.34 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
92
Manufacturing (kg CO2e)
330
Logistics (kg CO2e)
47
Use (kg CO2e)
113
EOL (kg CO2e)
3
Total Carbon w/o Use Phase (kg CO2e)
379
PAIA Version
9/5/2018
Limited warranty - 3 years
Bundled Services
10 - 80% (non-condensing)
CDS9 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £139.14
CDS9 StarTech.com Dual Monitor Stand In Stock £82.12
CDS9 StarTech.com TV/Monitor Arm - Wallmount In Stock £84.28
CDS9 StarTech.com Monitor Arm - Heavy Duty In Stock £95.48
