Dell 22 Monitor P2219H -22" 1920x1080 HDMI, DisplayPort, VGA, DVI
Quicklinx: DXMMWS00 Mfr#: DELL-P2219H
Optimize your workspace with this efficient 21.5" monitor built with an ultrathin bezel design, a small footprint and comfort-enhancing features. Take advantage of additional desk space and multitasking features. Increase your productivity by up to 18% when working on dual monitors. Focus on your work with an adjustable setup featuring cable organization and go easy on the eyes with ComfortView.
  • Transform how you work
  • Push your productivity
  • Expand your efficiency
  • Designed to fit the way you work
Dell P2219H - without stand - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/344547
Energy Class
Class E
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
13.5 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (fast), 8 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931)
Input Connectors
HDMI, VGA, DisplayPort
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
48.73 cm x 4.13 cm x 29.34 cm
2.75 kg
Environmental Standards
ENERGY STAR Qualified
Carbon Footprint
445 kg carbon emissions
Plug and Play, DDC/CI, RoHS, EDID compatible, DisplayPort 1.2
Bundled Services
3-Years Advanced Exchange Service and Premium Panel Guarantee
Display Type
Energy Class
Class E
28 kWh
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% (CIE 1931)
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
LED edgelight system, Dell Custom Color, Flicker Free technology, BFR/PVC-free, Mercury free, Dell ComfortView, arsenic free
48.73 cm x 4.13 cm x 29.34 cm - without stand
2.75 kg
DisplayPort , VGA , HDMI , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , 2 x USB 2.0 downstream (Type A)
Mechanical
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Input Voltage
13.5 W
13.5 kWh/1000h
Power Consumption (Typical)
17 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Dell Display Manager
Shipping Weight
4.64 kg
Sustainability Information
ENERGY STAR Certified
Carbon Footprint
Total CF/unit Standard Deviation (kg CO2e)
96
Manufacturing (kg CO2e)
325
Logistics (kg CO2e)
23
Use (kg CO2e)
97
EOL (kg CO2e)
1
Total Carbon w/o Use Phase (kg CO2e)
349
PAIA Version
1.2.6, 2019
Bundled Services
20 - 80% (non-condensing)
