D-Link's DWR-953 Wireless AC750 4G LTE Router allows you to access and share your super-fast 4G LTE mobile broadband with multiple devices. Once connected, you can transfer data, stream media, and send SMS messages. Simply insert your SIM card and share your 4G LTE Internet connection through a secure wireless network or by using any of the four Fast Ethernet LAN ports. Simultaneous 4G LTE/3G mobile Internet and fixed broadband Internet support allows you to combine Internet connections to give you faster Internet speeds. You can also set up fail-safe Internet should either connections fail.
- D-Link DWR-953 - wireless router - WWAN - Wi-Fi 5 - desktop
- Wireless router - wireless cellular modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Mobile Communication Protocol
- GSM, GPRS, UMTS, EDGE, HSPA, HSPA+, DC-HSPA+, FDD LTE, TDD LTE
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- NAT support, SPI, WPS, reset button
- IEEE 802.3u, IEEE 802.3i, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- 17 cm x 18 cm x 8 cm
- 400 g
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- Wi-Fi Rating
- AC1200
- Status Indicators
- Power, signal strength, WAN, LAN, 3G, SMS, Internet, 4G, 2.4/5 GHz, 2G
Communications
- Wireless cellular modem
- Max Transfer Rate
- 150 Mbps
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Expansion Slots
- 1 (total) / 1 (free) x SIM
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Power Device
- External power adapter
- 17 cm
- 18 cm
- 8 cm
- 400 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
