D-Link Eagle Pro AI AX3200 Mesh WiFi System (3-pack)
Quicklinx: H1MLWS00 Mfr#: M32-3
£135.07 ex VAT
£162.08 inc VAT
The D-Link EAGLE PRO AI M32-3 Wi-Fi system enhances connectivity in your home or office. Equipped with Wi-Fi 6 technology, it supports faster speeds and more devices simultaneously. With a total data transfer rate of up to 3.2 Gbps and dual-band support, this system ensures uninterrupted streaming, gaming, and browsing.
Security is a top priority, and the D-Link EAGLE PRO AI M32-3 meets this need with advanced encryption standards, including WPA3, to keep your network secure. The system also supports voice control through Alexa and Google Assistant, integrating seamlessly into any smart home ecosystem.
Designed for extensive coverage, the three routers work together to cover up to 740 sq.m, ensuring reliable Wi-Fi throughout your space. Whether in a large home or a multi-story office, the D-Link EAGLE PRO AI M32-3 provides a stable and fast Internet connection.
  • Enhanced connectivity
    With dual-band support offering 2.4 GHz and 5 GHz frequencies, the D-Link EAGLE PRO AI M32-3 ensures a more reliable connection. The device's ability to operate on Wi-Fi 6 technology enhances overall network efficiency and supports a larger number of connected devices.
  • Robust security
    This Wi-Fi system is equipped with multiple encryption algorithms including WPA, WPA2-Personal, WPA3, and WPA3-Personal, ensuring a secure and private connection. The inclusion of WPS further simplifies the process of connecting devices securely.
  • Seamless integration
    Designed to work effortlessly with intelligent assistants like Alexa and Google Assistant, the D-Link EAGLE PRO AI M32-3 allows for easy voice control, making it a perfect fit for modern smart homes.
  • High-speed performance
    Offering a data transfer rate of up to 3.2 Gbps and featuring technologies like MU-MIMO and OFDMA, the device is built to provide fast and efficient Wi-Fi to all connected devices, reducing lag and buffering.
  • Extensive coverage
    With a coverage area of up to 740 sq.m and the inclusion of three routers, this Wi-Fi system ensures comprehensive coverage throughout your home or office, eliminating dead zones and providing a stable connection everywhere.
D-Link EAGLE PRO AI M32-3 - Wi-Fi system - Wi-Fi 6 - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
3 routers
Wi-Fi System Coverage
Up to 740 sq.m
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
3.2 Gbps
Performance
Maximum data rate (2.4 GHz): 800 Mbps , Maximum data rate (5 GHz): 2402 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE
Routing Protocol
Static IP routing
Intelligent Assistant
Google Assistant, Alexa
Remote Management Protocol
HTTP
QoS, WPS, dynamic IP mode, MU-MIMO technology, guest access, TWT, BSS Coloring
IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11h, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v, IEEE 802.11ax
16.461 cm x 7.107 cm x 18.565 cm
486 g
Wi-Fi system - mesh - 2-port switch (integrated)
3 routers
Up to 740 sq.m
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
3.2 Gbps
Performance
PPTP, L2TP, PPPoE
Routing Protocol
Static IP routing
HTTP
Encryption Algorithm
WPA, WPS, WPA3, WPA3-Personal, WPA2-Personal
Wi-Fi Rating
AX3200
Mesh Networking
IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11h, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v, IEEE 802.11ax, FCC, IEC 62443-4-1
Status Indicators
Status
Line Properties
Line Coding Format
1024 QAM, OFDMA
Internet of Things (IoT)
WAN: 1 x 1000Base-T - RJ-45 , LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
4
Directivity
Omni-directional
External power adapter
15.51 Watt
16.461 cm
7.107 cm
18.565 cm
486 g
10 - 90% (non-condensing)
Brand: D-Link
