The DWL-6600AP is designed to be the best-in-class indoor Access Point for business environments. With high data transmission speeds, load balancing features, it can be deployed as a standalone wireless Access Point or used as the foundation for a managed wireless network.
Performance without compromise
Using the wireless N technology, the DWL-6600AP delivers great wireless performance and coverage in a compact design. -
Broadcast on 32 SSIDs simultaneously
Supports up to 32 SSIDs, 16 per radio, including Station Isolation. -
Smart design
The DWL-6600AP has a discrete design, similar in look to a smoke detector, so that it can be mounted easily onto any wall or ceiling without looking out of place in an office or home. -
Managed using D-Link's wireless controller or unified wireless switch
All D-Link's unified wireless access points can be managed using D-Link's wireless controller or unified switch. -
Simultaneous dual-band wireless
Supports up to 300Mbps for the 5Ghz band and up to 300Mbps for the 2.4Ghz band. -
Fast seamless roaming
Combining the DWL-6600AP with a unified wireless switch or controller allows you to create a wireless network that enables people to move freely around a building without losing connectivity. -
Secure and green design
The DWL-6600AP has a wireless scheduler feature, which turns off wireless functionality when it isn't needed, saving power and increasing network security. -
Versatility built as standard
Whether you intend to use a single access point or roll out a large corporate network, the DWL-6600AP coupled with a D-Link wireless controller or Switch makes managing your wireless network simple.
- D-Link Unified N Simultaneous Dual-Band PoE Access Point - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External - indoor
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Maximum number of configured SSIDs: 32
- Power Over Ethernet (PoE) Supported
- PoE
- 15.6 cm x 15.6 cm x 7.75 cm
- 500 g
- Ruggedized Design
- Indoor
- 15.6 cm
- 15.6 cm
- 7.75 cm
- 500 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 600 Mbps
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, SSH
- Frequency Band
- 2.4 GHz, 5 GHz
- Max Range Indoors
- 100 m
- Capacity
- MAC address filtering, Wireless Distribution System (WDS) support, Wireless Intrusion Detection System (WIDS), Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, 2T2R MIMO technology, rogue access point detection, 802.1x authentication
- Encryption Algorithm
- WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WEP
- Authentication Method
- Secure Shell (SSH)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Aerial
- Antenna
- External detachable
- 1 x 1000Base-T - RJ-45 , 1 x console - RJ-45 , 4 x aerial
- FCC Class B certified, VCCI, C-Tick, cUL, IC, UL 2043, EN 60950-1, EN 60601-1-2, TELEC, LVD, NCC
- PoE
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
