D-Link Switch - 54 ports - Managed stackable  48 x 10/100/1000(PoE)
Quicklinx: FD93WS00 Mfr#: DGS-3130-54PS/SI#SP
The DGS-3130 Series switches are Lite Layer 3 Stackable Managed Switches designed to connect end-users in a secure enterprise or metro Ethernet access network. These switches support multicast, and enhanced security, making them an ideal Gigabit access layer solution. The DGS-3130-54TS provides 48 10/100/1000 Mbps Gigabit Ethernet ports. The DGS-3130-54PS provides 48 10/100/1000 Mbps Power over Ethernet (PoE) Gigabit Ethernet ports. The DGS-3130-54S provides 48 SFP Gigabit Ethernet ports. Each 10/100/1000 Mbps port on the DGS-3130-54PS supports the 802.3af and 802.3at PoE standards. The default power budget for these models is 370 watts and can be expanded to 740 watts with the DPS-700 RPS. The switches are also equipped with an USB 2.0 port, allowing the user to boot images and upload configuration files directly from, as well as conveniently save syslog files onto a USB 2.0 storage device.
  • Enhanced network reliability
    The DGS-3130 Series targets enterprises and metro Ethernet applications, and customers who require a high level of network security and maximum uptime. All the models in the DGS-3130 Series support an external redundant power supply to ensure continued operation. They also include reliability features, such as 802.1D Spanning Tree (STP), 802.1w Rapid Spanning Tree (RSTP), and 802.1s Multiple Spanning Tree (MSTP), Loopback Detection (LBD), and Broadcast Storm Control, that enhances network resilience. G.8032 Ethernet Ring Protection Switching (ERPS) minimizes the recovery time to 50 ms. For load sharing and redundancy backup in a switch cascading/server attachment configuration, the DGS-3130 Series provides dynamic 802.3ad Link Aggregation Port Trunking.
  • Comprehensive security
    The DGS-3130 Series provides users with the latest security features such as Multi-layer and Packet Content Access Control Lists (ACL), Storm Control, and IP-MAC-Port Binding (IMPB) with DHCP Snooping. The IP-MAC-Port Binding feature allows administrators to bind a source IP address with an associated MAC and also define the port number to enhance user access control. With the DHCP Snooping feature, the switch automatically learns IP/MAC pairs by snooping DHCP packets and saving them to the IMPB white list.
  • Easy access control policies
    The DGS-3130 Series supports authentication mechanisms such as 802.1X, Webbased Access Control (WAC), and MAC-based Access Control (MAC) for strict access control and easy deployment. After authentication, individual policies such as VLAN membership, QoS policies, and ACL rules can be assigned to each host. In addition, the switch also supports Microsoft NAP (Network Access Protection). NAP is a policy enforcement technology that allows customers to protect network assets from compromised computers by enforcing compliance with network health policies.
  • Versatile traffic management
    The DGS-3130 Series implements a rich set of multilayer QoS/CoS features to ensure that critical network services such as VoIP, video conferencing, IPTV, and IP surveillance are given high priority. Traffic Shaping features guarantee bandwidth for these services when the network is busy. L2 Multicast support enables the DGS-3130 Series to handle growing IPTV applications. Hostbased IGMP/MLD Snooping allows multiple multicast subscribers per physical interface and ISM VLAN to send multicast streams in a multicast VLAN to save bandwidth and to provide better security to the backbone network. The ISM VLAN profiles allow users to bind/replace the pre-defined multicast registration information to subscriber ports quickly and easily.
  • Proactive, effective network management
    To uphold enterprise customers' Service Level Agreements (SLA), service providers must reduce their Mean Time to Repair (MTTR) and increase service availability.
D-Link DGS 3130-54PS - switch - 54 ports - Managed
Switch - 54 ports - L3 Lite - Managed - stackable
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE) + 2 x 10 Gigabit Ethernet + 4 x 10 Gigabit SFP+
PoE Budget
370 W
Performance
Switching capacity: 216 Gbps , Forwarding performance (64-byte packet size): 161 Mpps
Packet buffer size: 4 MB , Units per virtual stack: up to 32 , IGMP groups: 1024 , Virtual interfaces (VLANs): 4000 , QoS hardware queues: 8
MAC Address Table Size
16384 entries
Jumbo Frame Support
9KB
Routing Protocol
RIP-1, RIP-2, IGMPv2, IGMP, VRRP, IGMPv3, static IPv4 routing, static IPv6 routing, RIPng, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, SNMP, Telnet, SNMP 3, SNMP 2c, TFTP, SSH-2, CLI, SFTP
Flow control, BOOTP support, IGMP snooping, port mirroring, sFlow, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, DHCP server, MLD snooping, Cable Diagnostics Function, bandwidth control, LLDP support, DHCP relay, Port Security, DHCP client, SP, 4MB packet buffer, SIM, ERPS, 2 fans, IGMP filtering, system log, ICMP, MIB II, AAA, VLAN Double Tagging (Q-in-Q), WAC, DNS client, proxy ARP, EEE, BPDU Filter, WRR, HOL Blocking Prevention, loopback detection, Telnet server, Telnet client, Root Restriction
IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
Power Redundancy
Optional
44 cm x 35 cm x 4.4 cm
5.14 kg
Subtype
Gigabit Ethernet
Ports
PoE Budget
370 W
Performance
16384 entries
Jumbo Frame Support
9KB
Max Units In A Stack
12
Routing Protocol
Encryption Algorithm
SSL, SSL 3.0, SSL 2.0
Authentication Method
Secure Shell v.2 (SSH2)
48 x 1000Base-T RJ-45 , 2 x 10GBase-T RJ-45 , 4 x 10GBase-X SFP+ , 1 x 10/100/1000 Base-T RJ-45 console , 1 x 10/100/1000 Base-T RJ-45 management , 1 x USB 2.0 Type A
Power Redundancy
Optional
487.26 Watt
MTBF
356,876 hours
FCC Class A certified, BSMI, cUL, CB, CCC, IC, VCCI Class A, RCM
Software Included
Standard Image (SI) Software
44 cm
35 cm
4.4 cm
5.14 kg
50 °C
10 - 90%
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
90%
