D-Link's DCS-6616 12X WDR Day/Night Speed Dome Camera is a PTZ surveillance solution that can cover large areas and low-light environments. Built with a Sony Super HAD-II 1/4" CCD sensor, the DCS-6616 can capture 650 TVL high-resolution video with excellent image quality. A built-in IR-cut removable filter allows the camera to capture video in both bright and dark environments.
- D-Link DCS 6616 - network surveillance camera
- Network surveillance camera - pan / tilt / zoom
- Audio
- Yes: two-way audio capability
- 1.2 kg
- Connectivity Technology
- Wired
- Camera
- Optical Zoom
- 12 x
- Max Resolution
- 720 x 576
- Optical Sensor Type
- CCD - 1/4"
- Minimum Illumination
- 0.1 lux - colour , 0.01 lux - B&W
- Focal Length Control
- Motorized zoom
- Focal Length
- 3.8 mm - 45.6 mm
- Focus Adjustment
- Automatic
- Lens Iris
- F/1.6-2.7
- Ethernet 10Base-T/100Base-TX
- Motion sensor, date/time stamp, progressive scanning, SD-card slot, Power over Ethernet, e-mail alerts, image flip, image mirror, Wide Dynamic Range (WDR), heater, built-in cooling fan, light sensor, infrared cut filter
- Environmental Parameters (operating)
- 0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
- Audio Support
- Wired
- 1.2 kg
Camera
- Colour - pan / tilt / zoom
- Digital Video Format
- MPEG-4, MJPEG, 3GPP, H.264
- Max Digital Video Resolution
- 720 x 576
- Infrared LEDs
- 12
- Video Capture
- 720 x 480 @ 30 fps , 352 x 240 @ 30 fps , 176 x 120 @ 30 fps , 720 x 576 @ 25 fps , 352 x 288 @ 25 fps , 176 x 144 @ 25 fps
- Supported Image Formats
- JPEG
Image Sensor
- CCD 1/4"
Lens Construction
- Motorized zoom
- Optical Zoom
- 12 x
- Focal Length
- 3.8 mm - 45.6 mm
- Lens Iris
- F/1.6-2.7
- Focus Adjustment
- Automatic
- Horizontal Field of View (degree)
- 4.49 - 52.8
- Vertical Field of View (degree)
- 3.4 - 39.7
- Network Interface
- Network Protocols
- DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ICMP, RTSP, RTP, HTTPS, UPnP, IPv4, RTCP, PPPoE, Samba, 3GPP/ISMA
- 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
- C-Tick, ICES-003, FCC
- Power Device
- Power adapter - external DC 12 V 14 Watt
- OS Required
- Microsoft Windows 2000/XP/Vista/7
- 0 °C
- 40 °C
- Relative Humidity (operating)
- 20 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
