D-Link mydlink Home Panoramic HD Camera
Quicklinx: CV0BWS00 Mfr#: DCS-8200LH
  • microSDHC Card
  • microSD Card
The mydlink Home Panoramic HD Camera allows you to monitor more of your home with a single camera. Forget pan, forget tilt, see everything instantly in full color high definition 720p with sound. The integrated microSD card slot1 allows you to record videos directly onto the camera when motion or sound is detected, without the need of a computer. It's easy to setup, connects to your home Wi-Fi and can even alert you when motion or sound is detected. What's more, it works with other mydlink Home smart devices to enable you to create a smart home without complicated setup, installation cost or monthly subscription charges.
mydlink Home Panoramic HD Camera - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in microphone
9.58 cm x 9.58 cm x 13.75 cm
165 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Frame Rate (max)
30 frames per second
Motion Detection
Optical Sensor Type
CMOS - 1/2.7"
Minimum Illumination
0.5 lux - colour , 0.1 lux - B&W , 0 lux - IR
Focal Length Control
Fixed focal
Focal Length
1.72 mm
Focus Adjustment
(min distance 50 cm)
Lens Iris
F/2.0
IEEE 802.11g, IEEE 802.11n, IEEE 802.11a, IEEE 802.11ac
Voltage
DC 5 V
Date/time stamp, Motion Detection Technology, sound activated recording, password protection
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wireless
9.58 cm
9.58 cm
13.75 cm
165 g
Camera
Colour - Day&Night - fixed
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Motion Detection
Digital Zoom
8
Infrared Distance
5 m
Digital Video Capture Resolution
1280 x 720, 720 x 480, 640 x 360
Frame Rate (max)
Image Sensor
CMOS 1/2.7"
Lens Construction
Fixed focal
Focal Length
1.72 mm
Lens Iris
F/2.0
Min Focus Distance
50 cm
Horizontal Field of View (degree)
180
Vertical Field of View (degree)
120
Network Interface
Supported Memory Cards
microSD Card, microSDHC Card
FCC Class B certified, C-Tick, ICES, LVD
Power Requirements
DC 5 V
Power adapter - external 4.8 Watt
Relative Humidity (operating)
