D-Link mydlink Home Monitor HD
Quicklinx: CQGNWS00 Mfr#: DCS-935LH
  • microSDHC Card
  • microSD Card
The mydlink Home Monitor HD allows you to monitor your home, whenever, from wherever. See everything in full color high definition 720p with sound. The built-in night vision allows you to see up to 5 meters even in complete darkness. It's easy to setup, connects to your home Wi-Fi and can even alert you when motion or sound is detected. What's more, it works with other mydlink Home smart devices to enable you to create a smart home without complicated setup, installation cost or monthly subscription charges.
  • Monitor everything
    This high-definition camera delivers high-quality video for remote viewing on the tablet or smartphone you already own.
  • Mydlink Home app-enabled
    Use the free mydlink Home app to view what your Monitor HD sees, using your tablet or smartphone to control it wherever you are in the world.
  • Wireless connectivity
    Connect the Monitor HD to your Wireless home network, easily and conveniently, using one-button setup.
  • Motion detection with night vision
    Never miss a thing with the ability to be notified when motion is detected, and night vision ensures clear images even in low-light conditions, so you can always see what the Monitor HD sees.
  • HD clarity
    See all the details with high definition 720p color images with sound.
  • Easy to setup
    Simply press a button to securely connect to your home Wi-Fi network with Wi-Fi protected setup. No additional control hub needed.
  • High definition
    Monitor your home in crystal clear HD 720p. See everything in detail, even when zoomed in.
  • See in the dark
    Built-in night vision function allows you to see up to 5 meters even in complete darkness.
  • Motion and sound detection
    Alerts you with push notification whenever motion or sound is detected.
mydlink Home Monitor HD - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in microphone
5.8 cm x 8.45 cm x 12.49 cm
160 g
Wireless
Camera
Colour - Day&Night
Max Resolution
1280 x 720
Optical Sensor Type
CMOS - 1/4"
Minimum Illumination
0 lux - IR - F2.4
Focal Length
2.38 mm
Focus Adjustment
(min distance 434 mm)
Lens Iris
F/2.4
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Voltage
DC 5 V
Motion sensor, date/time stamp, sharpness control, progressive scanning, saturation control, brightness control, contrast control, infrared cut filter, hue control, Wi-Fi Protected Setup (WPS), text stamp
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wireless
5.8 cm
8.45 cm
12.49 cm
160 g
Camera
Colour - Day&Night - fixed
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
1280 x 720
Digital Zoom
4
Exposure Range
1/7.5 sec - 1/24000 sec
0 lux - IR - F2.4
Infrared Distance
5 m
Digital Video Capture Resolution
1280 x 720, 720 x 480, 640 x 480, 320 x 240, 800 x 600
Supported Image Formats
JPEG
Image Sensor
CMOS 1/4"
Lens Construction
Focal Length
2.38 mm
Lens Iris
F/2.4
Min Focus Distance
434 mm
Horizontal Field of View (degree)
78.44
Vertical Field of View (degree)
47.9
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, RNCP, RTSP, RTP, HTTPS, UPnP, IPv4, Bonjour, PPPoE
Supported Memory Cards
microSD Card, microSDHC Card
FCC Class B certified, C-Tick, LVD
Power Requirements
DC 5 V
3.5 Watt
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8
Relative Humidity (operating)
