D-Link mydlink Home Door/Window Sensor (mydlink Connected Home Hub)
Quicklinx: CFZ6WS00 Mfr#: DCH-Z110
The mydlink Home Door/Window Sensor is a contact sensor that detects when a door or window is opened or closed, providing you with a trigger for automating your home. Integrating with D-Link's HNAP protocol, the Door/Window Sensor connects seamlessly with your the connected home hub, guaranteeing compatibility and getting your smart home network up and running right away.
  • Peace of mind
    Detect when a door or window is opened or closed. Know when people come and go in your home or monitor off-limit areas like medicine cabinets.
  • 3-in-1 sensor
    Detect when a door is opened or closed as well as monitor room temperature and light.
  • Your mydlink Home
    mydlink Home allows you to start with a single smart device and add more when you want to. The unique mydlink Home App for iOS and Android smartphone and tablet gives you control of all your other mydlink Home devices. You can even set up automation rules to make your home smarter.
  • Set up, control, monitor and protect your home
    The mydlink Home - Connected Home Hub acts as the link between your existing Wi-Fi network and all mydlink Home devices.
mydlink Home Door/Window Sensor - multipurpose sensor - Z-Wave
Multipurpose sensor
Sensor Type
Ambient light, door and window, temperature
Wireless - Z-Wave
Frequency Band
868.4 MHz
Europe
Multipurpose sensor
Sensor Type
Wireless - Z-Wave
Frequency Band
868.4 MHz
CR123A lithium battery
Europe
Encryption Algorithm
128-bit AES
FCC
Dimensions & Weight Details
Multipurpose sensor: 9.6 cm x 2.8 cm x 2.3 cm , Magnet: 5 cm x 1 cm x 1.2 cm
-10 °C
20 - 90% (non-condensing)
