D-Link DXS-5000 48-port with 6x QSFP+ Managed L3 10GbE Switch
Quicklinx: F9GCWS00 Mfr#: DXS-5000-54S/SI
The D-Link 5000 Series data center switches are a series of high-performance switches that feature high port density, routing, and ultra-low latency, designed to be deployed as Top-of-Rack (ToR) or leaf-spine switches in data center applications. Combined with ONIE support and increased cost-efficiency, the 5000 Series forms a flexible long-term solution for managing and expanding data center infrastructures in a Software-defined Networking (SDN) environment.
  • Open networking support
    The 5000 Series switches support open networking, providing IT professionals with innovative third-party operating systems and software options. This lowers costs by separating software from hardware and increases network agility and flexibility. With support for standards-based tools and standards-based applications, open networking simplifies scalability and future-proofs the network.
  • High availability and reliability
    The 5000 Series switches feature a modular fan and power supply design for high-availability architecture. The hot-swappable design means that fans and power supplies can be replaced without affecting switch operation. Load sharing enables both power supplies to evenly distribute load to increase reliability and lifetime. Meanwhile, 1+1 redundancy minimizes downtime in case of a single power supply failure.
  • Cost-efficient solution
    Compared to traditional switches, the 5000 Series offer a more cost-efficient solution through a lower initial purchasing cost combined with a reduced long term Total Cost of Ownership (TCO). The 5000 Series switches feature front-to-back and back-to-front airflow which optimizes air circulation inside the rack and facilitates the building of energy-efficient data centers by separating the hot and cold aisles. The switches also feature built-in smart fans; internal heat sensors monitor and detect temperature changes, and react accordingly by utilizing different fan speeds for different temperatures. At lower temperatures, the fans will run more slowly, reducing the switch's power consumption and noise.
D-Link DXS 5000-54S/SI - switch - 48 ports - rack-mountable
Switch - 48 ports
Enclosure Type
Back to front airflow rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
48 x 10 Gigabit SFP+ + 6 x 40 Gigabit QSFP+
Performance
Switching capacity: 1440 Gbps , Forwarding rate: 1071 Mpps
MAC Address Table Size
288K entries
Jumbo Frame Support
9KB
Routing Protocol
BGP, IGMPv2, IGMP, OSPFv2, IGMPv3, OSPFv3, static IPv4 routing, static IPv6 routing, ECMP, policy-based routing (PBR), MLDv2, MLD, VRRPv2, Bidirectional Forwarding Detection (BFD)
Remote Management Protocol
RMON 1, RMON 2, SNMP, RMON 3, RMON 9, Telnet, CLI, DHCP
ARP support, IGMP snooping, port mirroring, WRED, STP support, VRRP support, DCBX support, DHCP snooping, ACL support, QoS, SSH support, MLD snooping, reset button, ECMP, RSPAN, 12MB packet buffer, CoS, ToS, DSCP support, 4 fans, BPDU, ICMP IRDP, VXLAN, AAA, Root Guard, Loop Guard, flow mirroring, VLAN mirroring, WDRR, ToR, BPDU Filter, loopback detection, BPDU Guard
IEEE 802.1D, IEEE 802.1Q, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1s, IEEE 802.1Qbb, IEEE 802.1Qaz, IEEE 802.1Qau
Power Redundancy
44 cm x 40.6 cm x 4.4 cm
9 kg
No operating system
Switch - 48 ports
Enclosure Type
Subtype
10 Gigabit Ethernet
Ports
Performance
288K entries
Jumbo Frame Support
9KB
Routing Protocol
Authentication Method
RADIUS, TACACS+
X Intel: 2.4 GHz
RAM
8 GB DDR3 SDRAM
Built-in Devices
64 GB SSD
Status Indicators
Status
48 x 10GBase-X SFP+ , 6 x 40GBase-X QSFP+ , 1 x console mini-USB , 1 x management (Gigabit LAN) RJ-45 , 1 x USB 2.0 Type A
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
550 Watt
295 Watt
MTBF
205,000 hours
BSMI, CB, CCC, FCC, cULus
Software Included
Open Network Install Environment
No operating system
44 cm
40.6 cm
4.4 cm
9 kg
Limited warranty - lifetime
45 °C
5 - 95%
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95%
