D-Link 16-Port Gigabit Smart Managed Switch
Quicklinx: J7KJWS00 Mfr#: DGS-1100-16V2
Type: Gigabit Ethernet
Ports: 16
Managed: Yes
£78.79 ex VAT
£94.54 inc VAT
The DGS-1100 Series is a range of switches designed to meet the requirements of small, medium, and enterprise businesses. Support for multiple PoE standards make the DGS-1100 Series ideal for IP surveillance deployments. Advanced management features, a range of diagnostic and troubleshooting tools, and energy-efficient technologies provide a flexible solution to meet your networking requirements.
  • Gigabit Ethernet speed
    High-speed ports provide the Ethernet technology while retaining backward compatibility for connections to older computers and equipment.
  • Revolutionary energy efficiency
    Innovative D-Link Green features help conserve energy without sacrificing performance so you can reduce operating costs and protect the environment.
  • Smart and flexible management
    Powerful switch management functions can be performed through the web management interface or through a client-based utility.
  • Advanced features
    The switch is equipped with advanced security features such as Static MAC, Storm Control, and IGMP Snooping.
D-Link DGS 1100-16V2 - switch - 16 ports - smart - rack-mountable
Switch - 16 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
Switching capacity: 32 Gbps , Forwarding performance: 23.81 Mpps
VLAN groups: 128 , VLAN IDs: 4094 , IGMP groups: 128
MAC Address Table Size
8K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 2, ICMP
Flow control, auto-negotiation, BOOTP support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, QoS, Cable Diagnostics Function, bandwidth control, fanless, LLDP support, Port Security, DHCP client, 512KB packet buffer, tagged VLAN, DSCP support, IGMP querier, Voice VLAN, VLAN management, VLAN group, EEE, WRR, HOL Blocking Prevention, loopback detection, port-based VLAN, port-based QoS, Unknown Storm Control, DNA support, Asymmetric VLAN
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1ab (LLDP), IEEE 802.3az
28 cm x 18 cm x 4.4 cm
1.21 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
10240 bytes
Routing Protocol
SNMP 2, ICMP
Encryption Algorithm
SSL
: 500 MHz
RAM
128 MB
Flash Memory
16 MB
Status Indicators
Power, status, link/activity/speed
24 x 1000Base-T RJ-45
Internal power supply
10.1 watt
Power Consumption Stand by
3.4 watt
4 rubber feet, 2 x 19" mounting brackets
Rack Mounting Kit
Included
MTBF
710,519 hours
FCC Class A certified, C-Tick, BSMI, cUL, CB, CCC, RoHS, LVD, VCCI Class A
Software Included
D-Link Network Assistant
28 cm
18 cm
4.4 cm
1.21 kg
-5 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
Ports: 16
Managed: Yes
Brand: D-Link
