D-Link DWL-2600AP/E Unified Wireless N PoE Access Point
Quicklinx: CQH0WS00 Mfr#: DWL-2600AP/E
  • IEEE 802.11n
The DWL-2600AP unified N single-band PoE access point is a best-in-class indoor access point designed specifically for business-class environments. With high data transmission speeds and access point load balancing, the DWL-2600AP offers high-quality and reliable wireless service. Versatile and powerful, the DWL-2600AP can be flexibly deployed as a standalone wireless access point or as a managed access point controlled by a D-Link unified wireless switch or wireless controller. Businesses can start with standalone mode deployment, and then migrate to a centrally managed system anytime later.
  • Enhanced performance
    The DWL-2600AP delivers reliable wireless performance with maximum wireless signal rates of up to 300 Mbps with its 2 x 2 MIMO 2.4 GHz radio. Support for Wi-Fi Multimedia (WMM) Quality of Service features makes the DWL-2600AP an ideal access point for audio, video, and voice application. In addition, the load balancing feature ensures maximum performance and best service quality in the wireless environment.
  • Configuration replicating clusters
    For small business that need to deploy multiple access points (APs) but lack the resources to tackle the complicated task of network management, the DWL-2600AP's clustering feature offers the ideal solution. When a small number of DWL-2600APs is deployed on the network, they may be configured to form a cluster. Once the administrator is through with configuring one access point, the same configuration can then be applied to all remaining APs that are members of that cluster.
  • Unified management
    The DWL-2600AP can operate in conjunction with a D-Link wireless switch or wireless controller. In this mode, multiple DWL-2600APs can connect directly or indirectly to one of these switches or controllers to provide unparalleled security and wireless mobility for wireless clients. Each DWL-2600AP can be tuned by these switches to provide the optimal RF channels and transmission power for all mobile clients, giving them the best wireless signals in the 2.4 GHz band and uninterrupted wireless connectivity.
  • Security
    The DWL-2600AP supports the latest standards in Wi-Fi security, including WEP, WPA, WPA2, and 802.1X. In addition, the DWL-2600AP supports up to 16 virtual access points (VAP) per radio, which allows the administrator to assign different access privileges to different groups of users. When Station Isolation is enabled, the AP blocks communication between wireless clients on the same radio and VAP. Rogue APs in the network may be easily detected, and the administrator will be immediately notified of any security threat.
  • Automatic RF management
    When a number of access points are deployed close to each other, interference may result if proper RF management is not implemented. When a DWL-2600AP senses any neighbor AP at startup, it will automatically select a no interfering channel. The DWL-2600AP will automatically lower its transmission power to minimize interference. When that managed AP is no longer present, the DWL-2600AP will increase it's transmit power to expand coverage.
  • Quality of Service
    The DWL-2600AP is WMM-certified, so in the event for network congestion, time-sensitive traffic can be given priority ahead of other traffic. Furthermore, when a number of DWL-2600APs are in close proximity with each other, an access point can refuse association request once its resources are fully utilized. Instead, the association request will be picked up by a neighboring AP. This feature ensures that no single AP is over burdened while other APs nearby sit idle.
  • Convenient installation
    With an embedded antenna and simple styled exterior, the DWL-2600AP can be installed on a wall or ceiling and blends in with most interior decorations in an office.
D-Link Wireless N Unified Access Point DWL-2600AP - radio access point - Wi-Fi
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
16 cm x 16 cm x 4.5 cm
272 g
Radio access point
Ruggedized Design
Indoor
16 cm
16 cm
4.5 cm
272 g
External
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz
Status Indicators
Power, WLAN, LAN
Load balancing, VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, Multiple SSID support, rogue access point detection, ceiling mountable
Encryption Algorithm
WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n
Aerial
Antenna
Internal
1 x 100Base-TX (PoE) - RJ-45 , 1 x management - RJ-45
FCC
PoE
10 - 90% (non-condensing)
