With its built-in ADSL modem, the DSL-2640B connects to a phone socket and provides a secure and high-speed Internet access for homes and offices.
Setting up the router and adapter is easy even for non-technically minded people, with D-Link Click'n Connect: run directly from the product CD-ROM, this wizard takes you through an interactive step-by-step guide, including installation of the adapter.
A powerful dual firewall (SPI and NAT) prevents Denial of Service (DoS) attacks and attempts to breach your network from the Internet. You can also define a list of allowed sites to restrict web access during certain periods.
Enhanced security
Equipped with 128-bit WEP, 64-bit WEP, and WPA2 encryption algorithms, this DSL modem ensures your network remains secure against unauthorized access and threats. -
Versatile connectivity
With support for Ethernet 10Base-T/100Base-TX and ADSL2+ interfaces, along with wireless capabilities, this device offers flexible options for both wired and wireless connections. -
Comprehensive networking features
Features such as DoS attack prevention, IGMP snooping, MAC address filtering, NAT support, and Quality of Service (QoS) provide a robust solution for managing network traffic and enhancing security. -
High-speed Internet access
Supporting ADSL, ADSL2, and ADSL2+ protocols, the DSL-2640B modem facilitates fast Internet connections with a maximum transfer rate of 24 Mbps, suitable for streaming, gaming, and downloading large files. -
Easy network management
Integrated 4-port switch and compatibility with Windows 7 allow for straightforward setup and management of your home or office network, ensuring a hassle-free Internet experience.
- D-Link DSL-2640B - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
- Frequency Band
- 2.4 GHz
- PPTP, L2TP, ICMP/IP, IPSec, PPPoE, PPPoA
- Routing Protocol
- RIP, RIP-2, static IP routing
- Remote Management Protocol
- SNMP 1, SNMP 2c, HTTP
- Firewall protection, DMZ port, dynamic IP address assignment, DHCP support, NAT support, auto-uplink (auto MDI/MDI-X), IGMP snooping, SPI, DoS attack prevention, packet filtering, dynamic DNS server, MAC address filtering, VPN passthrough, WDS support, firmware upgradable, SNTP support, WMM support, QoS
- IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e
- Power
- AC 120/230 V (50/60 Hz)
- 19.6 cm x 12.1 cm x 3.2 cm
- 327 g
- Microsoft Certification
- Compatible with Windows 7
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- Routing Protocol
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA2, WPA-PSK
- Authentication Method
- RADIUS, Radio Service Set ID (SSID)
- IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11e, CSA, EN55022, EN55024, FCC Part 15 B, RoHS, EN 300 328
- Built-in Devices
- Radio access point
- Status Indicators
- Port status, power, status
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.5, ITU G.992.1 (G.DMT) Annex A, ITU G.992.5 Annex M, ITU G.992.3 Annex M
- Max Transfer Rate
- 24 Mbps
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11 , Management: 1 x console
Aerial
- Directivity
- Omni-directional
- Power Device
- External power adapter
- Voltage Required
- Cables Included
- 1 x network cable , 1 x phone cable
- 19.6 cm
- 12.1 cm
- 3.2 cm
- 327 g
- 0 °C
- 40 °C
- 5 - 95%
Customer reviews
Write a review for the D-Link DSL-2640B ADSL2/2+ Modem with Wireless Router here!
Excellent Router
Reviewed by Anonymous Review Posted 07/05/2008
Excellent, works well. Gets a little hot but nothing to worry about.
RE: MAC Address filtering. Not checked mine, but MAC filtering is minimal security at best. MAC Spoofing is very easy to do, and so is capturing packets to find the address. Just use WPA2, MAC filtering is not worth the hastle TBH
Overall
Ease of use
Value for money
Excellent modem/router...
Reviewed by Richard Thomas. Review Posted 15/01/2008
Love it. I have no experience with networks, and this is my first venture into broadband, but had absolutely no problems installing this modem. As soon as you open the box, it says "Insert CD first!", so I did. The on-screen instruction are very clear and easy to follow, and it auto-configured my modem without a problem. Wireless transmission strength is ok, travelling through two rooms and upstairs in my semi easily enough, but then again I do have a Edimax free-aerial WiFi card in my desktop, not one of these silly little USB stick things. The result is a "poor" signal strength, but the transmission rate on "poor" is still three times my broadband connection speed, so there's no slow-down of internet at all :-) Box includes 2 micro-filters, an ethernet patch cable, and two DSL cables. Unit looks neat, although it would be nice to have a vertical mount stand to reduce its footprint a bit. Only had it one day, but I'd already recommend it :-)
Overall
Ease of use
Value for money
MAC address filtering?
Reviewed by Dave L. Review Posted 28/02/2008
Had this modem/router foisted on me after my DSL-G624T died on me after 2 weeks. It took about 7 weeks from first reporting the issue with D-Link to get a replacement. Their email based support is woefully slow and formats the emails badly.
Generally happy with it apart from trying to set up MAC address filtering which is barely mentioned in the manual and not at all in the web based config utility.
I would probably not buy another D-Link product based on this experience.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
