D-Link DIR-809 - Wireless router - 4-port switch - 802.11a/b/g/n/ac
Quicklinx: D0W9WS00 Mfr#: DIR-809/B
  • IEEE 802.11n
The DIR-809 Wireless AC750 Dual Band Router is an affordable yet powerful wireless networking solution which combines the latest high-speed 802.11ac Wi-Fi specification with dual-band technology and fast Ethernet ports to deliver a seamless networking experience.
D-Link DIR-809 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
750 Mbps
Remote Management Protocol
HTTP
Firewall protection, DMZ port, NAT support, manageable, WPS
18.995 cm x 13.297 cm x 0.811 cm
228.6 g
Apple MacOS X 10.4 or later, Microsoft Windows XP SP3, Microsoft Windows Vista / 7 / 8
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
750 Mbps
HTTP
Encryption Algorithm
WPA, WPA2
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, BSMI, CCC, ANATEL, NCC
Built-in Devices
Led panel
Status Indicators
Power, WLAN, LAN, WPS, Internet
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External integrated
Antenna Qty
3
Gain Level
5 dBi
External power adapter
18.995 cm
13.297 cm
0.811 cm
228.6 g
10 - 90% (non-condensing)
