This transceiver uses the industry-standard Small form Pluggable (SFP) package. It slides into the mini-GBIC slot of the Gigabit device. Like all D-Link mini-GBIC transceivers, it is hot-swappable: you can remove or replace the transceiver with the system powered on, which allows modules to be added or swapped without interrupting the network.
- D-Link DEM 311GT - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-SX
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 550 m
- Designed For
- D-Link Data Center 10; DES 12XX, 30XX; DGS 12XX, 3100, 32XX, 3630; DWS 3024; DXS 1100, 1210, 3400, 3600; L2+ Gigabit Wireless Switch; Nuclias Cloud-Managed DBS-2000-10, 2000-28, 2000-52; Web Smart DGS-1216, 1224, 1248, DXS-1210-12; xStack DES-3526, 3528, 3552, 3828, DGS-3426, 3612, 3627, 3650
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-SX
- 1GbE
- 1 Gbps
- 850 nm
- 550 m
- 1 x Ethernet 1000Base-SX - LC multi-mode x 2
- Compatible Slots
- 1 x SFP (mini-GBIC)
- Designed For
- D-Link Data Center 10GbE Top-of-Rack Switch DXS-3600 ¦ D-Link DES 1210, 1226G, 3010G, 3028, 3028P, 3052, 3052P, 3250TG, 3350SR, 3526, 3550 ¦ D-Link DGS 1024T, 1210-10P/ME, 1216T, 1224T, 1248T, 3100-24, 3100-24P, 3100-24TG, 3100-48, 3100-48P, 3200-10, 3200-16, 3224TGR, 3312SR, 3324SR, 3324SRi, 3630-28SC, 3630-28TC, 3630-52TC ¦ D-Link DWS 3024L ¦ D-Link DXS 1100-16SC, 1210-12SC, 1210-16TC, 3400-24SC, 3400-24TC, 3600-16S ¦ D-Link L2+ Gigabit Wireless Switch DWS-3024 ¦ D-Link Nuclias Cloud-Managed DBS-2000-10MP, DBS-2000-28MP, DBS-2000-52MP ¦ D-Link Web Smart DES-1228, DES-1252, DGS-1216T, DGS-1224T, DGS-1248T, DXS-1210-12TC ¦ D-Link xStack DES-3526, DES-3528, DES-3528P, DES-3552, DES-3828, DES-3828DC, DES-3828P, DES-3852, DGS-3426, DGS-3426P, DGS-3427, DGS-3450, DGS-3612G, DGS-3627, DGS-3627G, DGS-3650, DXS-3326GSR, DXS-3350SR
