D-Link D-Link Wireless N PoE Outdoor Access Point
Quicklinx: D0WFWS00 Mfr#: DAP-3320
  • IEEE 802.11n
The DAP-3320 Wireless PoE Outdoor Access point is the ideal solution for expanding the coverage and signal strength of any wireless network. Built to withstand outdoor environments, the DAP-3320 also excels in connecting separate networks that cannot be joined using physical wiring.
  • Convenient design
    Built for outdoor use, the DAP-3320 has an IP55 weatherproof housing that protects it from weather. In addition, the DAP-3320 is powered by PoE which allows for convenient installation, especially in places where a power supply is not available.
  • Simplified outdoor connectivity
    Low cost Outdoor Access Point, with high power radio design the DAP-3320 is ideal for providing wireless connectivity between two locations.
  • Broadcast on 8 SSIDs simultaneously
    Supports up to 8 SSIDs per Band that can logically divide the access point into several virtual access points all within a single hardware platform.
  • 2.4Ghz single-band wireless
    The built-in 2 dBi omnidirectional antenna ensures that wireless signal will cover a wide area.
  • Free wireless AP controller software
    D-Link's free Central Wifi Manager is a cloud enabled wireless Access Point management tool, designed to allow you to create and manage multi-site, multi-tenancy wireless networks.
  • Manage up to 1000 APs
    Manage up to 1000 Access Points located around the world from one virtual controller residing in your network or in the cloud.
  • Scalable, flexible, centralized AP management
    Manage up to 1000 Access Points from a central location, regardless of geography.
D-Link DAP-3320 - radio access point - Wi-Fi
Radio access point
External - outdoor
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
3.586 cm x 10.543 cm x 22.86 cm
370.4 g
Radio access point
Ruggedized Design
Outdoor
3.586 cm
10.543 cm
22.86 cm
370.4 g
External
Wireless
Data Transfer Rate
300 Mbps
Network / Transport Protocol
ARP
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz
Status Indicators
ARP support, VLAN support, MAC address filtering, Wireless Distribution System (WDS) support, Quality of Service (QoS), Network Access Protection (NAP), reset button, Wireless Client Mode, Traffic Control, 802.1x authentication
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-Enterprise, WPA2-Enterprise
Authentication Method
Secure Shell (SSH), RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Directivity
Omni-directional
Gain Level
2 dBi
1 x 100Base-TX (PoE) - RJ-45
UL, IC, FCC, IP55
PoE
-20 °C
60 °C
0 - 90% (non-condensing)
