D-Link Covr Whole Home - Wi-Fi system (3 extenders)
Quicklinx: F032WS00 Mfr#: COVR-C1203/B
  • IEEE 802.11n
  • Cover your whole home with one seamless network
    Gone are the days of only being able to use Wi-Fi in certain areas of your home. Thanks to revolutionary smart roaming technology, the Covr AC1200 dual band whole home Wi-Fi system continually scans the wireless signal strength to your devices, automatically connecting them to the strong signal. The Covr AC1200 dual band whole home Wi-Fi system handles the transfer seamlessly, allowing you to walk from room to room without experiencing dropped Internet voice/video calls or frozen video streams. You enjoy seamless connectivity no matter where you are in the house. Covr ensures your entire home is covered by a single, seamless network using a single Wi-Fi, making interrupted connections, drop-outs, and dead spots things of the past.
  • High-speed wired and wireless connectivity
    With Covr you can bring the full potential of AC1200 Wi-Fi to any area in your home, including dead spots. Each Covr Point creates its own exclusive high-speed AC1200 Wi-Fi zone for communication with your wireless devices, allowing you to fully experience demanding multimedia applications from anywhere in your home. In addition, Gigabit Ethernet ports give you solid, dependable wired performance for devices such as Network Attached Storage (NAS), Smart TVs, and gaming consoles.
  • MU-MIMO and Smart Steering technology
    The Covr AC1200 dual band whole home Wi-Fi system features MU-MIMO Wi-Fi, which transmits data to multiple wireless devices simultaneously to increase speed and efficiency. Enjoy increased throughput and seamless high-definition streaming media, Internet phone calls, online gaming, and content-rich web surfing throughout your entire home or office with Covr.
  • Easily expand your network
    The Covr AC1200 dual band whole home Wi-Fi system provides you with a home network solution that is quick and easy to set up. The Covr Points work straight out of the box, so you just need to plug them in and get started.
D-Link Covr Whole Home - Wi-Fi system - Wi-Fi 5
Wi-Fi system
Wi-Fi System Components
3 extenders
Wi-Fi System Coverage
Up to 465 sq.m
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz / 5 GHz
Auto-negotiation, auto-uplink (auto MDI/MDI-X), MIMO technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), reset button, MU-MIMO technology, Air Time Fairness (ATF)
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
10.9 cm x 11.7 cm x 5.1 cm
250 g
Wi-Fi system
3 extenders
Up to 465 sq.m
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA, WPA2, 128-bit AES
Wi-Fi Rating
AC1200
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, Plug and Play, UL, CB, IC, FCC, RoHS, ERP, iDA, RCM
Status Indicators
Status
WAN / LAN: 2 x 1000Base-T - RJ-45
Aerial
Aerial
Internal
Antenna Qty
3
3.5 Watt
10.9 cm
11.7 cm
5.1 cm
250 g
10 - 90% (non-condensing)
