The DSL-2640R wireless ADSL router is an affordable high performance ADSL router fit for homes and small offices. With integrated ADSL2/2+ supporting up to 24Mbps download speed, 802.11g wireless LAN, firewall protection, Quality of Service (QoS) and 4-port switch, this router provides all the essentials that a home or small office needs to establish a secure and high-speed remote link to the outside world.
Ultimate Internet connection
The DSL-2640R wireless ADSL router is an affordable high performance ADSL router fit for homes and small offices. With integrated ADSL2/2+ supporting up to 24Mbps download speed, 802.11g wireless LAN, firewall protection, Quality of Service (QoS) and 4-port switch, this router provides all the essentials that a home or small office needs to establish a secure and high-speed remote link to the outside world. -
Affordable high-speed connection for homes and small offices
Designed as a very affordable high performance ADSL router for home and SOHO users, the DSL-2640R provides not only low-cost, high-speed Internet connection, but also the security and Quality of Service (QoS) required by users in today's high risk and versatile Internet environments. -
Ready wired and wireless LAN connection
The DSL-2640R provides an integrated 802.11g WLAN interface supporting wireless speeds of up to 54Mbps and interoperability with 802.11b wireless devices on the 2.4GHz frequency band. It also provides four 10/100Mbps Ethernet switch ports for ready workstations connection. These built-in functions save you the cost and trouble of installing a separate wireless access point and an Ethernet switch. -
Firewall protection and QoS
Security features prevents unauthorized access to the home and office network from Internet intruders. The router provides firewall security using Stateful Packet Inspection (SPI) and Denial of Service (Dos) attack protection. SPI inspects the contents of all incoming packet headers before deciding what packets are allowed to pass through. Router access control is provided with packet filtering based on port and source/destination MAC/IP addresses. For Quality of Service (QoS), the router supports multiple priority queues to enable a group of home or office users to experience the benefit of smooth network connection of inbound and outbound data without concern of traffic congestion.
- D-Link DSL-2640R Wireless G ADSL2+ 4-Port Modem Router - wireless router - DSL - 802.11b/g - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 54 Mbps
- TCP/IP, PPTP, PPPoE, PPPoA
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- Telnet, HTTP
- Firewall protection, auto-sensing per device, DHCP support, NAT support, auto-uplink (auto MDI/MDI-X), traffic shaping, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, packet filtering, ALG support, DiffServ support, E-mail alert, MAC address filtering, VPN passthrough, parental control, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS)
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, UPnP
- Localisation
- United Kingdom
- 2 years warranty
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 54 Mbps
- Routing Protocol
- Static IP routing
- Telnet, HTTP
- Encryption Algorithm
- WPA-PSK
- Authentication Method
- Radio Service Set ID (SSID)
- Status Indicators
- Link activity, power
Line Properties
- Framing Format
- ANSI T1.413
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.4 (G.lite.bis), ITU G.992.1 (G.DMT) Annex A, ITU G.992.5 Annex A
- Max Transfer Rate
- 24 Mbps
- LAN : 4 x 10Base-T/100Base-TX - RJ-45 , WAN : 1 x ADSL2+ - RJ-11 , Management : 1 x console
Aerial
- Aerial
- External detachable
- Antenna Qty
- 1
- Gain Level
- 2 dBi
- Power Device
- Power adapter - external
- EN 60950, UL 1950, IEC 60950, EN 300.328, FCC Part 15 B, FCC Part 68, FCC Part 15 C
- Localisation
- United Kingdom
- 2 years warranty
- Service & Support Details
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 5 - 95%
