D-Link AC5300 Ultra - Wireless router - 4-port switch - GigE - 802.
Quicklinx: D0WBWS00 Mfr#: DIR-895L
  • IEEE 802.11n
The D-Link AC5300 Ultra Wi-Fi router delivers the outstanding performance customers are expecting today for the demanding tasks, like 4K video streaming, gaming and multiple device usage. It delivers breakthrough tri-band Wi-Fi technology with amazing combined wireless speeds. Thanks to 4x4 data streams, that can be combined through beamforming and MU-MIMO technology to increase reliability and range. The entire family can now enjoy 4K streaming and gaming on multiple devices without any lag.
  • The advanced Wi-Fi coverage
    Eight high-performance external antennas and high-power amplifiers will deliver improved Wi-Fi range and signal stability throughout your home. You'll connect to your devices faster and no more dead zones.
  • Multi-user MIMO (MU-MIMO)
    The DIR-895L/R is designed to support MU-MIMO technology that allows multiple devices to get high-bandwidth Wi-Fi signal at the same time, distributing data more efficiently, giving you the fast Wi-Fi speeds in your home. You can stream HD media faster, transfer large files really fast and play lag-free gaming.
  • More processing power
    Want a powerful high-performance processor that can handle multiple tasks at incredible speeds? An excellent processor boosts multitasking computing power and improves throughput speeds for all of your applications.
  • Improved user interface
    Controlling your network by enabling parental controls, blocking unwanted devices, monitoring Internet activity and creating Wi-Fi guest networks is easier than ever with the advanced interface.
  • Really fast wired performance
    Connect a few wired devices and enjoy the optimal online experience for HD streaming and gaming.
D-Link AC5300 Ultra - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
5332 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec
Firewall protection, NAT support, Stateful Packet Inspection (SPI), content filtering, print server, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, Zero Configuration Technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Green Ethernet, reset button, DLNA Media Server, SharePort Technology, VPN Server, Guest Zone support, MU-MIMO technology, Advanced AC SmartBeam technology, SmartConnect Technology
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac
26.272 cm x 41.773 cm x 14.96 cm
Apple MacOS X Lion 10.7, Microsoft Windows 7 / 8 / 8.1 / 10
1-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
5332 Mbps
PPTP, L2TP, IPSec
Encryption Algorithm
WPA, WPA2
Wi-Fi Rating
AC5300
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Wi-Fi Protected Setup, IEEE 802.11ac, FCC Class B certified, IPv6 Ready
1.4 GHz
Built-in Devices
Led panel
Status Indicators
Power, wireless, link/activity, USB
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
8
External power adapter
1 x network cable
26.272 cm
41.773 cm
14.96 cm
Limited warranty - parts and labour - 1 year
0 - 90% (non-condensing)
