D-Link's DXS-3600 Series Top-of-Rack 10 Gigabit Stackable Managed Switch consists of compact, high-performance switches that feature 10 Gigabit Ethernet switching, routing, and very low latency.
Standard features
The DXS-3600 switches support a wide range of Layer 2, VLAN, multicasting, Quality of Service (QoS), security, data center, and static routing functions. These features make the aggregation switch, with 40 Gbps uplink to the core, and 10 Gbps downlinks to the access. -
Energy efficient
The switches feature built-in smart fans; internal heat sensors monitor and detect temperature change, and react accordingly by utilizing different fan speeds for different temperatures. At lower temperatures, the fans will run slower and reduce the switch's power consumption and noise.
- D-Link DXS 3600-16S - switch - 8 ports - Managed - rack-mountable
- Switch - 8 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 8 x 10 Gigabit SFP+
- Performance
- Switching capacity: 480 Gbps , Forwarding performance: 357.14 Mpps
- MAC Address Table Size
- 128K entries
- Routing Protocol
- RIP-1, RIP-2, BGP, IGMPv2, IGMP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, PIM-SSM, DVMRPv3
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, Telnet
- IGMP snooping, Quality of Service (QoS)
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 50.6 cm x 4.4 cm
- 9.9 kg
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Ports
- Performance
- 128K entries
- Routing Protocol
- RAM
- 9 MB
- Status Indicators
- Port transmission speed, power, link/activity, console
- 8 x SFP+ , 1 x console - RJ-45 , 1 x management (Gigabit LAN) RJ-45
- Expansion Slots
- 1 SD Memory Card
- Power Device
- Internal power supply
- Voltage Required
- 74.3 Watt
- VCCI, C-Tick, cUL, CB, EMC, IC, FCC
- 44 cm
- 50.6 cm
- 4.4 cm
- 9.9 kg
- 0 °C
- 45 °C
- 0 - 95% (non-condensing)
- Min Storage Temperature
- 40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
