D-Link 20X Full HD High Speed Dome Network Camera
Quicklinx: 989CWS00 Mfr#: DCS-6915
The DCS-6915 Outdoor 20X Full HD WDR Speed Dome Network Camera is a high-definition professional surveillance and security solution suitable for small, medium, and large enterprises. The DCS-6915 features a 3 megapixel sensor capable of Full HD 1080p resolution, allowing for very clear surveillance footage to be taken. The powerful 20X optical zoom and 10X digital zoom ensure that you can see even the smallest details with ease.
  • Proportional pan, tilt, and zoom speeds
    Adjusting the camera is painless since the pan and tilt speed is proportional to the optical zoom ratio of the camera. When the camera zooms in, the panning speed is automatically slowed to improve camera tracking and controllability. PTZ presets allow the camera to monitor specified areas along predefined paths.
D-Link DCS-6915 Outdoor Speed Dome Full HD Camera - network surveillance camera
Network surveillance camera - pan / tilt / zoom - outdoor - vandal / waterproof
2.6 kg
Wired
Camera
Colour - Day&Night
Optical Zoom
20 x
Optical Sensor Type
CMOS - 1/2.8"
Minimum Illumination
0.8 lux - colour - F1.2 , 0.08 lux - B&W - F1.2
Focal Length Control
Motorized zoom
Focal Length
4.7 mm - 84.6 mm
Focus Adjustment
Automatic
Lens Iris
Auto iris
Panning Range (degree)
360
Tilting Range (degree)
-90 to +90
Ethernet 10Base-T/100Base-TX
SD-card slot, heater, ONVIF support, built-in cooling fan, auto backlight compensation, multi-streaming
Environmental Parameters (operating)
0 °C - 50 °C; 20 - 80% (non-condensing) relative humidity
Wired
2.6 kg
Camera
Colour - Day&Night - pan / tilt / zoom - outdoor - vandal / waterproof
Digital Video Format
MJPEG, H.264
Digital Zoom
10
Supported Image Formats
JPEG
Image Sensor
CMOS 1/2.8"
Lens Construction
Motorized zoom
Optical Zoom
20 x
Focal Length
4.7 mm - 84.6 mm
Lens Iris
Auto iris
Focus Adjustment
Automatic
Panning
Range (degree)
360
Speed (degree/sec)
Up to 300
Tilting
Range (degree)
-90 to +90
Speed (degree/sec)
Up to 200
Network Interface
Network Protocols
DHCP, DNS, FTP, HTTP, SMTP, TCP/IP, UDP/IP, ICMP, HTTPS, IPv4, IPv6, RTCP, IGMP, 3GPP/ISMA
Interfaces Details
1 x network - Ethernet 10Base-T/100Base-TX
FCC, IP66
Power adapter - external AC 100/230 V 65 Watt
Software Included
Drivers & Utilities
50 °C
Relative Humidity (operating)
989C C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.09
