D-Link 2-Bay NAS Network Storage Enclosure
Customer rating: 5.0* (Write a review)
Quicklinx: 49GVWS00 Mfr#: DNS-323
With the latest firmware installed, you will be able to download files without even switching on a computer: the officially licensed BitTorrent client lets you build your download list by simply uploading the torrent file or entering its web address in the web-based manager.
This Network Storage Enclosure enables users at home or in the office to share files across the network and over the Internet via the built-in FTP server. Connected to your router, it also provides a invaluable back-up of your files in case of system failure or virus damage to your computer. Back-up software is included with the product.
The DNS-323 accommodates up to two 3.5" SATA hard drives of any capacity (HD not included). Tools or cables are not required for setup. Simply slide the front cover, insert the drive(s) and slide the front cover back.
Content stored on the DNS-323 can be streamed to compatible media players, such as those found in D-Link's MediaLounge product line. That is done by the built-in UPnP AV media server, and this does not require a computer to be turned on. The DNS-323 also features an iTunes Server. When enabled, the DNS-323 will be automatically detected in the iTunes program, which means the software will be able to find and play music directly from the DNS-323.
The DNS-323 also includes a Gigabit port for better transfer speeds, a USB print server and power-saving features.
  • Efficient storage solution
    The D-Link DNS 323 2-Bay Network Storage Enclosure offers a versatile storage solution with its two internal 3.5" expansion bays, supporting HDDs in a compact form factor. This design allows for efficient use of space and easy storage expansion.
  • Flexible RAID configuration
    With support for RAID 0, RAID 1, and JBOD, the D-Link DNS 323 provides flexible options for data management and security. Users can choose the configuration that best suits their needs, whether it's for speed, data redundancy, or a combination of both.
  • High-speed connectivity
    Equipped with Gigabit Ethernet, the D-Link DNS 323 ensures fast and reliable data transfer rates, making it suitable for handling large files and supporting multiple users on the network without compromising performance.
D-Link DNS 323 2-Bay Network Storage Enclosure - NAS server
NAS server
Host Connectivity
Gigabit Ethernet
0 (installed) / 2 (max)
10.4 cm x 19.8 cm x 13.2 cm
1.22 kg ()
Storage Controller
RAID RAID 0, 1, JBOD
Network adapter 10Mb LAN, 100Mb LAN, 1GbE
NAS server
Host Connectivity
Gigabit Ethernet
10.4 cm
19.8 cm
13.2 cm
1.22 kg ()
Storage Controller
RAID - internal
Supported Devices
Hard drive
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - 3.5" x 1/3H
Network adapter
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Expansion Bays
2 (total) / 2 (free) x internal - 3.5" 1/3H
1 x Ethernet 1000Base-T - RJ-45
Software Included
Drivers & Utilities
55 °C
5 - 95%
Resources
The following resources are available for the D-Link 2-Bay NAS Network Storage Enclosure
Customer reviews
Write a review for the D-Link 2-Bay NAS Network Storage Enclosure here!
Excellent Enclosure
Reviewed by Sebastian Bettley. Review Posted 02/04/2008
I have had one of these for nearly a year now, and apart from some early glitches it has never let me down. I use with Linux and XP via CIFS. It has 2 500GB WD drives configured as RAID 1. Both the iTunes and Ftp servers work like a dream. Early problems in accessing in windows where drive kept disappearing from the network. This was solved by 1. editing windows>system32>drivers>etc>hosts to add the host name and IP address of the DNS323 and 2. binding the DNS 323's MAC address to an IP address. Some routers call this assigning a static IP address. No problems since I did this. I updated to firmware 1.03.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
great after firmware update
Reviewed by R York. Review Posted 25/01/2008
I had some initial problems with this drive, it used to hang and randomly corrupt file locations so you couldn't delete them. But after the firmware update it's been 100%.
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
Excellent Product
Reviewed by Colin. Review Posted 14/11/2007
I have now had one of these running for over 3 months with 2 Seagate 750 gig drives. Runs near silently if stood on some foam. Has performed without a hitch, even after a couple of powercuts.
Now beginning to look expensive compared to other options, however having experienced failures from both Maxtor and Buffalo NAS drives(one did a self test and pronounced itself dead, the other defaulted its menu to Japanese and could not be sorted by the on-line help) I will stick with self build.
  • Overall 5*
  • Ease of use 5*
  • Value for money 3*
Read all 14 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
