D-Link 1-meter 25G Passive SFP28 Direct Attach Cable
Quicklinx: J7M1WS00 Mfr#: DEM-CB100S28
£85.96 ex VAT
£103.15 inc VAT
The D-Link 25GBase direct attach cable is a networking solution designed to meet the demands of data-intensive applications. With SFP28 connectors on both ends, it offers reliable, high-speed connections that are essential for modern networking environments. The cable is constructed to comply with rigorous ANSI/EIA-364 standards, ensuring its durability and longevity. It operates efficiently across a wide temperature range, making it suitable for a variety of operational conditions. Whether for data centers, enterprise networking, or high-performance computing applications, this cable provides a dependable connection that helps maintain the integrity and speed of your network infrastructure.
  • Robust connectivity
    Equipped with SFP28 connectors on both ends, this 25GBase direct attach cable is designed to facilitate high-speed network connections, ensuring efficient data transfer rates for demanding applications.
  • Durable design
    The cable's construction adheres to stringent ANSI/EIA-364 standards, featuring a passive cable setup with an American Wire Gauge (AWG) of 30, making it both reliable and durable for extensive use in various environments.
  • Wide operating range
    Capable of operating in a broad range of temperatures, from as low as -40°C to as high as 75°C, this cable is built to maintain performance reliability under extreme environmental conditions.
D-Link 25GBase direct attach cable - 1 m
Passive cable
Length
1 m
Connector
SFP28
Connector (Second End)
SFP28
DMS 3130-30TS
Network Cable Type
30
Passive cable
Length
1 m
Connector
SFP28
SFP28
UL 94, MSA SFF-8432, ANSI/EIA-364, MSA SFF-8402, ANSI/EIA-364-1000.01
-40 °C
75 °C
D-Link DMS 3130-30TS
Brand: D-Link
