Featuring with surge protected RJ11/RJ45 port, the EX series UPS is ideal for home entertainment systems and SOHO networks with its full protection against surge/spikes and power abnormalities. With EMI/RFI filters eliminating line noise or disturbances, it could supply reliable backup during power interruptions, brownouts and blackouts. The space-wise tower design could be placed horizontally or vertically to make the most your work space!
- CyberPower EX Series EX850E - UPS - 490 Watt - 850 VA
- UPS - external
- 3 kg
- Localisation
- United Kingdom
- Output Voltage
- AC 230 V ± 5%
- Power Capacity
- 490 Watt / 850 VA
- Input Connectors
- 1
- Output connectors
- 1 (surge) , 2 (UPS and surge)
- Battery
- Lead Acid - 7 Ah
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- Run Time (Up To)
- 2 min at full load
- Networking
- USB
- 11 cm x 30.9 cm x 8.4 cm
- UPS - external
- Battery Enclosure Type
- Internal
- Localisation
- United Kingdom
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- 1
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 5% - 50/60 Hz
- Power Capacity
- 490 Watt / 850 VA
- Dataline Surge Protection
- Network/phone line - RJ-45/RJ-11 - 1 input line / 1 output line
- Surge Suppression
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Capacity
- 7 Ah
- Run Time (Up To)
- 2 min at full load , 7 min at half load
- Recharge Time
- 8 hours
- Remote Management Interface
- USB
- 1 x management (USB) - 4 pin USB Type B
- Cables Included
- Power cable - integrated , Phone cable - external , USB cable - external
- LED indicators, GreenPower UPS Technology, overload protection
- RoHS
- Software Included
- PowerPanel Personal
- 0 °C
- 40 °C
- 0 - 90% (non-condensing)
- 11 cm
- 30.9 cm
- 8.4 cm
- 3 kg
