Engineered to be compatible with your Apple system, Crucial Memory for Mac takes the guesswork out of a memory upgrade. Since Apple systems often have very specific memory requirements, including particular component densities, speeds, and SPD programming specifications, it's important to buy your memory from people who know Apple computers inside and out. With over a decade of experience manufacturing and developing memory for Apple systems, Crucial makes it easy to find memory that's been designed specifically for your system.
If you're an Apple computer user, you probably expect intuitive, reliable performance from your system. Crucial thinks memory should work the same way, too. For each module it manufactures, Crucial sends it through a rigorous testing process to ensure that you're getting a reliable, high-performance memory solution. Every module that leaves the doors has been extensively tested at the component level for voltage and temperature resistances, signal integrity, and software compatibility. Even better, Crucial modules are lead and halogen-free (DDR3 modules only). The result? Reliable memory that meets or exceeds Apple's own memory requirements.
Unsure how to install memory or have an important question about your Apple system? Let the team of experts help! With a tech-savvy team that's well-versed in Apple systems, Crucial will provide the technical support you need - no matter how old your Mac computer gets. From phone support, videos, FAQ articles, and do-it-yourself guides, Crucial has got the resources you need to keep your system up to speed.
Crucial is a trusted name when it comes to DRAM, and that's no coincidence. As a brand of Micron, one of the largest manufacturers of DRAM in the world, Crucial works with its engineers to design, refine, test, manufacture, and support an extensive line of memory modules. With a product portfolio that includes more than 250,000 different DRAM upgrades for more than 50,000 systems, Crucial has got one specifically designed for your Mac system. For more than a decade Crucial has kept Mac computer owners happy with high-performance memory and outstanding customer service. No matter what type of Mac system you have, Crucial has got a compatible solution.
Reliability for your systems
When you use your system, you expect intuitive, dependable performance. And if you're a Pro user, you expect mission-critical workstation reliability. Expect the same out of your memory. The module has been checked at the component level for voltage and temperature resistances, signal integrity, and software compatibility. Even better, modules are lead- and halogen-free. -
Speed and energy efficiency for your systems
A memory upgrade is the fast, easy, and affordable way to get more performance out of your system. These modules deliver amazing speeds for improved energy efficiency.
- Crucial - DDR3 - kit - 16 GB: 2 x 8 GB - SO-DIMM 204-pin - unbuffered
- Product Type
- Memory kit
- Capacity
- 16 GB: 2 x 8 GB
- Memory Type
- DDR3 SDRAM - SO-DIMM 204-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL11
- Unbuffered
- Voltage
- 1.35 / 1.5 V
- Limited lifetime warranty
- Designed For
- Apple iMac (Late 2011); Mac mini (Mid 2011); MacBook Pro (Early 2011, Late 2011)
- Capacity
- 16 GB: 2 x 8 GB
- Upgrade Type
- System specific
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- SO-DIMM 204-pin
- Speed
- Latency Timings
- CL11
- Non-ECC
- Unbuffered
- Voltage
- 1.35 / 1.5 V
- Compatible Slots
- 2 x memory - SO-DIMM 204-pin
- Colour Category
- Green
- Designed For
- Apple iMac (Late 2011) , Apple Mac mini (Mid 2011) , Apple MacBook Pro (Early 2011, Late 2011)
