Brand
Crucial 16GB DDR4 2666 MHz SODIMM CL19 Memory
Quicklinx: G604WS00 Mfr#: CT16G4SFRA266
Type: DDR4 SDRAM
Connection: SO-DIMM 260-pin
Speed: 2666MHz
Data Integrity: Non-ECC
Registered/Buffered: Unbuffered
More than 50 In Stock
£42.71 ex VAT
£51.25 inc VAT
There's an easy cure for a slow computer: more memory. Designed to help your system run faster and smoother, Crucial Laptop Memory is one of the easiest and most affordable ways to improve your system's performance. Load programs faster. Increase responsiveness. Run data-intensive applications with ease, and increase your laptop's multitasking capabilities.
Crucial - DDR4 - module - 16 GB - SO-DIMM 260-pin - 2666 MHz / PC4-21300 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2666 MHz (PC4-21300)
Latency Timings
CL19
Unbuffered
Voltage
1.2 V
Limited lifetime warranty (Germany - 10 years)
16 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL19
Non-ECC
Unbuffered
Voltage
1.2 V
Type: DDR4 SDRAM
Speed: 2666MHz
CAS Latency: CL19
Standard: PC4-21300
Brand: Crucial
