More speed. More bandwidth. More efficient.
In the ever-changing world of technology, any component more than half a decade old is usually in need of an update. At seven years old and counting, that's exactly the state DDR3 memory is in: computers can only do so much with it.
Since the introduction of DDR3 memory technology in 2007, processors have doubled in capability, SSDs have revolutionized throughput, and graphics cards have drastically increased frame rates, leaving memory as a limiting factor. With Crucial DDR4 Desktop Memory, crush the DDR3 memory bottleneck and unlock a new standard of performance.
CT8G4DFS8213 is a 8GB DDR4 desktop module that operates at speeds up to 2133 MT/s and has a CL15 latency. It is an Unbuffered DIMM. It conforms to the industry standard DDR4 ECC UDIMM layout of 288 pins and is compatible with systems that take DDR4 2133MT/s UDIMM memory.
Faster speed
Process data faster. Enable higher responsiveness, and increase memory bandwidth. With Crucial memory, introductory data rates get even faster as the technology matures. Crucial memory also delivers faster burst access speeds for improved sequential data throughput by utilizing 4-bank groups. -
Large capacity
Maximize system performance by doubling memory capacity. As memory technology matures, it will allow you to double your server's memory capacity and get more out of every module - and your entire network. Built, using smaller die, that allow more Gigabits per component, Crucial memory is designed to utilize higher density components to deliver modules, that are much more dense. -
More energy efficient
Reduce power and cooling expenses. Crucial memory uses less voltage technology, and operates at lower power. Combined with the additional power-saving features inherent in memory architecture, Crucial memory is able to deliver significant power savings. Also, since less heat is generated per module, it's easier to keep systems cool.
- Crucial - DDR4 - kit - 8 GB: 1 x 8 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - unbuffered
- Product Type
- Memory kit
- Capacity
- 8 GB: 1 x 8 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15
- Dual rank, unbuffered
- Voltage
- 1.2 V
- Limited lifetime warranty
- Capacity
- 8 GB: 1 x 8 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL15
- Non-ECC
- Chips Organization
- 512 x 8
- Voltage
- 1.2 V
- Colour Category
- Black, green
