Crucial 8GB (2x4GB) DDR3-1600 1.35V SODIMM Memory
Quicklinx: 8Y3QWS00 Mfr#: CT2KIT51264BF160B
In short, 204-pin small outline dual inline memory modules (SODIMMs) are the form factor used to provide DDR3 memory modules for notebook computers and other small form factor computing platforms. 204-pin SODIMMs are currently available in PC3-8500 (DDR3 1066MHz) and PC3-10600 (DDR3 1333MHz) speeds.
To use DDR3 memory, your system must have both a 204-pin SODIMM slot and a chipset that supports DDR3 memory. A DDR3 SODIMM will not fit into DDR2 or DDR memory sockets.
SODIMMs are smaller and thinner than regular DIMMs, and the 204-pin SODIMM PCBs are always ~2.6 inches long and are usually around 1.18 inches high (though the heights can vary slightly). They consist of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The number of memory components on a 204-pin SODIMM's printed circuit board (PCB) can vary, but the PCB will always have 102 pins on the front and the back both, for a total of 204 pins. The gold pins on the bottom of the SODIMM provide the connection between the memory module and the memory socket.
Crucial - DDR3L - kit - 8 GB: 2 x 4 GB - SO-DIMM 204-pin - 1600 MHz / PC3-12800 - unbuffered
Memory kit
8 GB: 2 x 4 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Unbuffered
Voltage
1.35 V
Lead Plating
Gold
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM memory kit
DDR3L SDRAM
SO-DIMM 204-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL11
Non-ECC
Unbuffered
Voltage
1.35 V
Lead Plating
Gold
