Crucial 48GB (3x16GB) DDR3L-1600 1.35V RDIMM Memory
Quicklinx: 9HPHWS00 Mfr#: CT3K16G3ERSLD4160B
Crucial 240-pin DIMMs are used in DDR3 memory for desktop computers. DDR3 is the latest generation of memory with an improved architecture that allows it to transmit data more quickly.
A dual inline memory module (DIMM) consists of a number of memory components (usually black) that are attached to a printed circuit board (usually green). The gold pins on the bottom of the DIMM provide a connection between the module and a socket on a larger printed circuit board. The pins on the front and back of a DIMM are not connected to each other.
To use DDR3 memory, your system motherboard must have 240-pin DIMM slots and a DDR3-enabled chipset. This is because a DDR3 SDRAM DIMM will not fit into a standard DDR2 DIMM socket or a DDR DIMM socket.
Crucial - DDR3 - kit - 48 GB: 3 x 16 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - registered
Memory kit
48 GB: 3 x 16 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Dual rank, Low Voltage, registered
48 GB: 3 x 16 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
DIMM 240-pin
Speed
ECC
Chips Organization
X4
Compatible Slots
3 x memory - DIMM 240-pin
