Crucial 2x1GB 184Pin DIMM PC3200 Non-ECC Unbuffered
Customer rating: 5.0* (Write a review)
Quicklinx: 3PYDWS00 Mfr#: CT2KIT12864Z40B
Crucial Technology offers customers a number of clear advantages over its competitors. As the only consumer memory upgrade supplier that's part of a major DRAM manufacturer, Crucial sells high-quality memory that has been qualified and approved by all major original equipment manufacturers. That's important to customers who need quality-assured memory for mission-critical applications. Crucial RAM makes your job easier.
Crucial - DDR - kit - 2 GB: 2 x 1 GB - DIMM 184-PIN - 400 MHz / PC3200 - unbuffered
Memory kit
2 GB: 2 x 1 GB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
400 MHz (PC3200)
Latency Timings
CL3
Unbuffered
Voltage
2.6 V
Apple M9654G/A, Kingston KFJ-E600/2G, Kingston KTA-G5400/2G, Kingston KVR400X64C3AK2/2G, Apple 065-4977, Apple M9298G/A
ABIT SG-80; Gigabyte GA-8IPE1000-G
2 GB: 2 x 1 GB
Upgrade Type
Generic
DRAM memory kit
DDR SDRAM
DIMM 184-PIN
Speed
400 MHz (PC3200)
Latency Timings
CL3
Non-ECC
Unbuffered
Module Configuration
128 x 64
Voltage
2.6 V
Compatible Slots
1 x memory - DIMM 184-PIN
ABIT SG-80 , Gigabyte GA-8IPE1000-G
Customer reviews
Write a review for the Crucial 2x1GB 184Pin DIMM PC3200 Non-ECC Unbuffered here!
RECOMMENDED
Reviewed by Anonymous Review Posted 30/01/2006
GREAT MEMORY AT REASONABLE PRICE. PLUS PEACE OF MIND AS IT'S CRUCIAL QUALITY. DABS SERVICE IS PRETTY GOOD TOO - I HAD NO PROBLEMS WITH THIS ORDER AND WILL DEFINATELY ORDER AGAIN.
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
Best price/capacity
Reviewed by Christo. Review Posted 05/04/2006
Build a system with £720:
Asustek A8N-SLI Premium
AMD Athlon 64 3700+ 1MB
Crucial 2x1GB PC3200 C3
Gainward GeForce 6800GS GLH 512MB
WD HDD Caviar 250GB S300 16MB 7200rpm
LG Electronics DVD +- R/RW/RAM 16x DL
Sony 1.44MB Internal 3.5"
DabsValue Gaming Case 480W
DabsValue 30-in-1 Internal USB Reader
Upgrade potential:
MB can take 64, 64x2 and FX S939
SLI enable 2nd Graphics card install if needed (512MB will bring you a long way)
2 empty DIMM slots (2GB additional if needed, total of 4GB)
Don't bother with the true 16x SLI MB, performance is the same!
Make sure to buy the Golden sample version of the graphics card.
Box does the job and airflow is great ... MB fits perfect ... 480W is more than enough for now.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Faster than a speeding bullet
Reviewed by Parkie. Review Posted 13/06/2006
Well Dabs does it again! Placed the order on Sunday night - Checked the order on monday night to see that Dabs was awaiting stock, due in about 2 days - First thing the following morning my parcel arrives! Dabs exceeding expectations as usual - well done!
  • Overall 5*
  • Ease of use 5*
Read all 16 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
