Enterprise-level performance. Tested, qualified, and reliable, Crucial server memory delivers enterprise-level performance. Crucial server memory is available in LRDIMM, FBDIMM, RDIMM, and unbuffered ECC module types. With a wide variety of speeds and densities to choose from, Crucial server memory is designed to meet the needs of server platforms and operating systems, both new and old. Trust Crucial memory for your server and workstation applications, and keep your important data running smoothly.
- Crucial - DDR2 - module - 2 GB - FB-DIMM 240-pin - 667 MHz / PC2-5300 - Fully Buffered
- Product Type
- Memory module
- Capacity
- 2 GB
- Memory Type
- DDR2 SDRAM - FB-DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- ECC
- Speed
- 667 MHz (PC2-5300)
- Latency Timings
- CL5
- Fully Buffered
- Voltage
- 1.8 V
- OEM Manufacturer Equivalent Part Number
- Kingston F25672F51, Kingston KVR533D2D8F4/2G, Kingston KVR667D2D8F5/2G, Kingston KVR667D2D8F5/2GI, Kingston KVR667D2D8F5V/2G, Kingston KVR667D2S4F5/2G, Crucial MT18HTF25672FDY-667E1D4, Crucial MT18HTF25672FDY-667E1N6, Crucial MT18HTF25672FDY-667G1D6, Crucial MT18HTF25672FDY-667G1N8, Crucial MT18HTF25672FDZ-667H1D4, Crucial MT18HTF25672FDZ-667H1D6, Crucial MT18HTF25672FDZ-667H1N8, Crucial MT36HTF25672FY-667F1E4, Crucial MT36HTF25672FY-667F1N6, HP 455263-061
- Designed For
- ASUS DSBF-D/SAS; Gigabyte GA-7BESH01, 7BESH-RH, 7GEWH-RH, 7VCSV-RH; Intel Server Board S5000; Iwill DPK66; MSI 5000P Master-A4M, 5000P Master-S8M; SUPERMICRO X7DA3, X7DA8, X7DAE, X7DAL, X7DB3, X7DB8, X7DB8+, X7DBE, X7DBE+, X7DBP, X7DBR, X7DBX, X7DVA, X7DVL; Tyan Tempest i5000
- Capacity
- 2 GB
- Upgrade Type
- Generic
- DRAM memory module
- Technology
- DDR2 SDRAM
- Form Factor
- FB-DIMM 240-pin
- Speed
- Latency Timings
- CL5
- ECC
- Fully Buffered
- Module Configuration
- 256 x 72
- Voltage
- 1.8 V
- Designed For
- ASUS DSBF-D/SAS , Gigabyte GA-7BESH01-RH, GA-7BESH-RH, GA-7GEWH-RH, GA-7VCSV-RH , Intel Server Board S5000PAL, S5000PSL, S5000VCL, S5000VSA , Iwill DPK66, DPK66S, DPK66S-SAS, DPK66S-SCSI, DPK66-V , MSI 5000P Master-A4M, 5000P Master-S8M , SUPERMICRO X7DA3, X7DA8, X7DAE, X7DAL-E, X7DB3, X7DB8, X7DB8+, X7DB8-X, X7DBE, X7DBE+, X7DBE-X, X7DBP-8, X7DBP-i, X7DBR-3, X7DBR-8, X7DBR-8+, X7DBR-E, X7DBR-I+, X7DBX-8, X7DBX-i, X7DVA-8, X7DVA-E, X7DVL-3, X7DVL-E, X7DVL-i , Tyan Tempest i5000PT S5383G2NR, S5383G4NR, S5383WG2NR, S5383WG4NR , Tyan Tempest i5000PW S5382WAG2NRF , Tyan Tempest i5000PX S5380G2NR, S5380G2NR-RS , Tyan Tempest i5000VF S5370G2NR, S5370G2NR-RS , Tyan Tempest i5000VS S5372G3NR , Tyan Tempest i5000XL S2692A2NR, S2692ANR , Tyan Tempest i5000XT S2696A2NRF, S2696WA2NRF
