Crucial 1GB 184pin DIMM PC3200 DDRRAM NP Unbuffered CL3.0
Customer rating: 5.0* (Write a review)
Quicklinx: 31B1WS00 Mfr#: CT12864Z40B
Help your desktop perform at its best. Designed to help your desktop run faster and smoother, a Crucial memory upgrade is one of fastest, most affordable, and easiest ways to improve your system's performance. Crucial memory empowers your desktop to achieve faster application loading times, faster system responsiveness, and increased ability to multitask and handle data-intensive programs. What does this mean? Spend less time staring at loading screens and more time getting stuff done. Crucial desktop modules are rigorously tested at both the component and module levels to ensure that your memory meets the stringent compatibility and performance standards. Every module manufactured is inspected by the Systems Compatibility Group before it leaves the doors. At a fraction of the price of your desktop, an investment in Crucial memory helps your system get up to speed.
Crucial - DDR - module - 1 GB - DIMM 184-PIN - 400 MHz / PC3200 - unbuffered
Memory module
1 GB
Memory Type
DDR SDRAM - DIMM 184-PIN
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
400 MHz (PC3200)
Latency Timings
CL3
Unbuffered
Voltage
2.6 V
Lead Plating
Gold
IBM 22P9272, HP DE468A, IBM 73P3223, HP DE468G, DELL A0388042, IBM 22P9274, IBM 33R4963, NEC PK-UG-ME011, DELL A0547734, DELL A0288600, DELL A0740413, DELL A0740372, DELL A0740408, DELL A0546961, DELL A0548449, DELL A0740381, DELL A0740385, DELL A0740386, DELL A0740389, DELL A0740390, DELL A0740397, DELL A0740400, DELL A0740404, DELL A0740416, DELL A0740419, DELL A0740420, DELL A0740421, DELL A0740433, DELL A0740448, DELL A0740456, DELL A0740460, HP 335700-005, HP 407311-001, HP 445716-885, DELL A2251711, Kingston D12864D30A, Kingston KFJ2847/1G, Kingston KTD8300/1G, Kingston KTH-D530/1G, Kingston KTM-M50/1G, Kingston KTN-PM400/1G, Kingston KVR400X64C3A/1G, Crucial MT16VDDF12864AY-40BF1, Crucial MT16VDDT12864AY-40BF2, Fujitsu S26361-F2847-E114, Fujitsu S26361-F2847-E115, Fujitsu S26361-F2847-L114, Fujitsu S26361-F2847-L115, IBM 73P3224, DELL A0740429, Kingston KTM3219/1G
ABIT SG-80; Gigabyte GA-8IPE1000-G
1 GB
Upgrade Type
Generic
DRAM memory module
DDR SDRAM
DIMM 184-PIN
Module Height (inch)
1.25
Speed
400 MHz (PC3200)
Latency Timings
CL3
Non-ECC
Unbuffered
Module Configuration
128 x 64
Voltage
2.6 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 184-PIN
ABIT SG-80 , Gigabyte GA-8IPE1000-G
Customer reviews
Write a review for the Crucial 1GB 184pin DIMM PC3200 DDRRAM NP Unbuffered CL3.0 here!
Great price - easy installation - amazing results
Reviewed by Kloffus. Review Posted 19/11/2008
Bought two of these to update a Dell Dimension 2400 from 256 MByte to 2 Gig. Used the memory selector, no problem. Ordered Saturday, arrived Wednesday - well packed as always. Took me longer to disconnect all the leads and open the computer than to actually fit the memory! No problems on reboot. Results are amazing - and for a third to a half of the price quoted by some well known stores. Would recommend without hesitation
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Reviewed by Acriduk. Review Posted 18/03/2008
I've always used Crucial Memory on numerous computer builds and never had an issue with them not a single failure. If you are looking for a general purpose memory stick these are great.
  • Overall 5*
  • Ease of use 5*
No probs
Reviewed by . Review Posted 08/02/2008
Been using it for 10 months now had now problems so far
  • Overall 5*
  • Ease of use 5*
Read all 12 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
