Crucial 16GB DDR4 DIMM 288-pin 2400 MHz/PC4-19200 CL17 1.2V unbuffered non-ECC
Quicklinx: C88LWS00 Mfr#: CT16G4DFD824A
Select:
More speed. More bandwidth. More efficient. The future of memory is here.
In the ever-changing world of technology, any component more than half a decade old is usually in need of an update. At seven years old and counting, that’s exactly the state DDR3 memory is in: computers can only do so much with it. Since the introduction of DDR3 memory technology in 2007, processors have doubled in capability, SSDs have revolutionized throughput, and graphics cards have drastically increased frame rates, leaving memory as a limiting factor. With Crucial DDR4 Desktop Memory, crush the DDR3 memory bottleneck and unlock a new standard of performance.
2x the Speed
Load applications faster and run demanding programs without lag. Crucial DDR4 memory debuts at 2133 MT/s – more than 30% faster than DDR3 memory technology. Even better, as DDR4 technology matures, speeds are projected to hit 3200 MT/s – twice what was possible on standard DDR3 memory.
2x the Bandwidth
Effortlessly multitask between apps, and empower your system to fire on all cylinders. Crucial DDR4 increases memory bandwidth by over 30%, allowing your system to handle more data at once. As DDR4 technology matures, bandwidths are expected to achieve up to 25.6 GB/s – twice that of standard DDR3. To maximize bandwidth, Crucial DDR4 memory is optimized for next-gen platforms that support four channel memory.
40% More Energy Efficient
Get better performance – using less power. Operating at just 1.2V compared to 1.5V for standard DDR3 memory, Crucial DDR4 consumes 20% less voltage than standard DDR3 technology. Crucial DDR4 modules also contain other efficiency features, for an overall power reduction of up to 40%.
Micron Quality - A Higher Level of Reliability
As a brand of Micron, one of the largest memory manufacturers in the world, Crucial DDR4 memory represents the future of computer performance. From the original DDR technology to DDR4, we’ve engineered the memory technologies that have powered the world’s computers for 35 years and counting. When you choose Crucial DDR4 memory, you’re choosing memory that’s backed by a limited lifetime warranty and designed for the world’s leading systems. Don’t settle for anything less.
Crucial - DDR4 - module - 16 GB - DIMM 288-pin / PC4-19200 - unbuffered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MT/s (PC4-19200)
Latency Timings
CL17
Dual rank, unbuffered
Voltage
1.2 V
Limited lifetime warranty (Germany - 10 years)
16 GB
Upgrade Type
Generic
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17
Non-ECC
Module Configuration
1024 x 64
Chips Organization
X8
Voltage
1.2 V
Colour Category
Green
