Crucial 16GB (8GBx2) DDR4 PC4 17000 2133MHz SODIMM Kit
Quicklinx: C4QTWS00 Mfr#: CT2K8G4SFD8213
  • Form Factor SODIMM
  • Capacity 16GB kit (8GBx2)
  • Specs DDR4 PC4-17000, CL=15, Dual Ranked, x8 based, Unbuffered, NON-ECC, DDR4-2133, 1.2V
  • NON-ECC
  • Kit Qty 2
  • Voltage 1.2V
  • DIMM Type Unbuffered
  • Component Configuration x8 based
Crucial - DDR4 - kit - 16 GB: 2 x 8 GB - SO-DIMM 260-pin - 2133 MHz / PC4-17000 - unbuffered
Memory kit
16 GB: 2 x 8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Dual rank, unbuffered
Voltage
1.2 V
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM memory kit
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL15
Non-ECC
Chips Organization
X8
Voltage
1.2 V
