The Sound Blaster ZxR is the flagship of the ultra high-performance Z-series of sound blaster PCI-express sound cards, elevating the standards of technology and performance for the future of gaming and entertainment on the PC. Designed to deliver the ultimate audio playback and creation solution for the PC, sound blaster ZxR personifies the ultimate gaming and entertainment performance for a sound card.
SNR 124dB
A signal to noise ratio or SNR of 124dB means your audio will be more than 99.99% pristine, which is over 85 times better than motherboard audio.
Crystal clear communication
In gaming, if you're not communicating, you're not winning. Experience crystal clear communication with your teammates with the CrystalVoice™ suite of technologies that removes echoes, ambient noises and picks up your voice from within a zone (Voice Focus). It also maintains your voice level even if you are near or further away from the microphone.
Studio-grade content creation
Add studio quality audio sound tracks or voice tracks to your video clips or home videos created with hardware that uses only audiophile-grade components such as 123dB analog-to-digital converters (ADCs) with RCA Aux-in and optical inputs for outstanding recording quality. With the 600 ohm headphone ampflier, you can do studio-grade monitoring as well.
High-quality DBPro daughter board
The DBpro is another reason why Sound Blaster ZxR delivers only the best audio playback and creation. It offers optical output for outstanding audio playback, plus professional-grade ADCs with RCA Aux-in and optical inputs for studio-grade recording quality.
SBX Pro Studio™ technologies
SBX Pro Studio™ sound technologies create unprecedented levels of audio realism, including stunning 3D surround effects for your speakers and headsets.
Accessible Audio Control Module (ACM)
Take control in style and ease with the ACM that incorporates a built-in microphone array and mic/headphone I/O connections. The knob on the ACM lets you conveniently adjust the headphone levels.
Sound Core3D audio processor
We designed the quad-core Sound Core3D™ audio processor to offload SBX Pro Studio and CrystalVoice effects processing from your primary CPU, improving your overall PC performance, resulting in drastically superior audio and voice quality.
High fidelity multi-channel surround
Connect to your home theatre system through a single digital cable and enjoy cinematic DVD movies by transforming any stereo or multi-channel streams into high fidelity immersive surround sound.
Never unplug your headphones again
With the Sound Blaster Z-series Control Panel, just toggle between your headphone and speaker system with a flip of a switch.
SNR 124 dB
A signal to noise ratio or SNR of 124 dB means your audio will be > 99.99% pure audio which is 34.4 times better than the average sound cards. -
In gaming, if you're not communicating, you're not winning. Experience crystal clear communication with your teammates with the CrystalVoice suite of technologies that removes echoes, ambient noises and picks up your voice from within a zone (Voice Focus). It also maintains your voice level even if you are near or further away from the microphone. -
Add studio quality audio sound tracks or voice tracks to your video clips or home videos created with hardware that uses only audiophile-grade components such as 123dB analog-to-digital converters (ADCs) with RCA Aux-in and optical inputs for outstanding recording quality. With the 600 ohm headphone amp flier, you can do studio-grade monitoring as well. -
The DBpro is another reason why Sound Blaster ZxR delivers only the best audio playback and creation. It offers optical output for outstanding audio playback, plus professional-grade ADCs with RCA Aux-in and optical inputs for studio-grade recording quality. -
SBX Pro Studio technologies
SBX Pro Studio sound technologies create unprecedented levels of audio realism, including stunning 3D surround effects for your speakers and headsets. -
Take control in style and ease with the ACM that incorporates a built-in microphone array and mic/headphone I/O connections. The knob on the ACM lets you conveniently adjust the headphone levels. -
Creative Technology designed the quad-core Sound Core3D audio processor to offload SBX Pro Studio and CrystalVoice effects processing from your primary CPU, improving your overall PC performance, resulting in drastically superior audio and voice quality. -
Connect to your home theater system through a single digital cable and enjoy cinematic DVD movies by transforming any stereo or multi-channel streams into high fidelity immersive surround sound.
- Creative Sound Blaster ZxR - sound card with expansion module
- Sound card with expansion module
- Enclosure Type
- Internal
- Interface Type
- PCI Express x1
- Signal Processor
- Sound Core3D
- Sound Output Mode
- 5.1 channel surround
- DAC Resolution
- 24-bit
- Sample Rate
- 8 kHz (min) - 192 kHz (max)
- Signal-To-Noise Ratio
- 124 dB
- System Requirements
- Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
- 1-year warranty
- Form Factor
- Internal
- Interface Type
- PCI Express x1
Processor / Memory
- Signal Processor
- Sound Core3D
Audio Output
- Sound Output Mode
- DAC Resolution
- 24-bit
- Sample Rate
- 124 dB
- Frequency Response
- 10 - 45000 Hz
- CrystalVoice, SBX Pro Studio
- OpenAL, Dolby Digital Live, DTS Connect, EAX ADVANCED HD 5.0
- Audio Modes
- Playback: 24-bit 192 kHz , Record: 24-bit 96 kHz
- 1 x headphones - phone stereo 6.35 mm , 1 x speakers - RCA x 2 , 1 x speakers (center/subwoofer) - mini-phone stereo 3.5 mm , 1 x speakers (rear) - mini-phone stereo 3.5 mm , 1 x microphone - phone stereo 6.35 mm , On DBpro Daughter Board: 1 x TOSLINK input - TOSLINK , On DBpro Daughter Board: 1 x TOSLINK output - TOSLINK , On DBpro Daughter Board: 1 x audio line-in - RCA x 2 , On Audio Control Module: 1 x audio line-in/microphone - mini-phone stereo 3.5 mm , On Audio Control Module: 1 x audio line-in/microphone - phone stereo 6.35 mm , On Audio Control Module: 1 x audio line-out/headphones - mini-phone stereo 3.5 mm , On Audio Control Module: 1 x audio line-out/headphones - phone stereo 6.35 mm
- Included Accessories
- DBPro daughter board, Audio Control Module
- Cables Included
- 1 x audio (optical) cable , 1 x mini-phone 3.5 mm to 2 x RCA adapter
- Software
- Drivers & Utilities, Creative Software Suite, Creative Diagnostics, Creative ALchemy
- OS Required
- System Requirements Details
- Windows 7 (32/64 bits) - Core 2 Duo - 2.2 GHz - RAM 1 GB - HD 600 MB
- Limited warranty - 1 year
