Sound Blaster Audigy Fx is the perfect upgrade from basic motherboard audio to legendary Sound Blaster audio. Powered by SBX Pro Studio technology, it provides high-quality 5.1 cinematic sound for your movies, music and games. It comes with the Sound Blaster Audigy Fx Control Panel, which puts you in full control of your SBX Pro Studio settings.
- Creative Sound Blaster Audigy Fx - sound card
- Sound card
- Enclosure Type
- Internal
- Interface Type
- PCI Express x1
- Sound Output Mode
- 5.1 channel surround
- DAC Resolution
- 24-bit
- Sample Rate
- 192 kHz (max)
- Signal-To-Noise Ratio
- 106 dB
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
- Sound card
- Form Factor
- Internal
- Interface Type
- PCI Express x1
Audio Output
- Sound Output Mode
- DAC Resolution
- 24-bit
- Sample Rate
- 192 kHz (max)
- 106 dB
- SBX Pro Studio
- OpenAL, EAX ADVANCED HD 5.0
- Audio Modes
- Record: 24-bit 96 kHz , Playback: 24-bit 192 kHz stereo - 106 dB , Playback: 24-bit 192 kHz 5.1 - 106 dB
- 1 x headphones - mini-phone 3.5 mm , 1 x speakers (rear) - mini-phone 3.5 mm , 1 x speakers (center/subwoofer) - mini-phone 3.5 mm , 1 x microphone - mini-phone 3.5 mm , 1 x audio line-in - mini-phone stereo 3.5 mm
- Included Accessories
- Low-profile bracket
- Software
- Drivers & Utilities, Creative Software Suite, Creative Diagnostics, Creative ALchemy
- OS Required
- System Requirements Details
- Windows Vista/7/8 - Core 2 Duo - 2.2 GHz - RAM 1 GB - HD 600 MB
