The Corsair TX650W power supplies are engineered using advanced technology and components typically found with high performance power supplies. With design features such as a dedicated, single +12V rail offer the maximum compatibility with the latest system components. Energy efficient circuitry capable of delivering greater than 80% efficiency ratings across 20%, 50%, and 100% load conditions make the TX family of PSUs is ideal for the value/quality conscious enthusiast. Enthusiasts looking for the optimal in price performance PSU technology will find the Corsair TX series of PSUs will meet even the most demanding of required specifications. The Corsair TX650W/TX750W power supplies are engineered using advanced technology and components typically found with high performance power supplies. With design features such as a dedicated, single +12V rail, the TX series offers the maximum compatibility with the latest system components. Energy efficient circuitry capable of delivering greater than 80% efficiency ratings across 20%, 50%, and 100% load conditions make the TX family of PSUs ideal for the value/quality conscious enthusiast. With a large 120mm on TX650W diameter temperature-controlled fan that is ultra quiet, yet still more than sufficient to cool the internals of the system, reliability and stability are no longer worries for the gamer, overclocker or enthusiast and high-end system builder. Each Corsair TX power supply is backed with an industry-leading 5-year warranty and 24/7 on-demand customer service
- CORSAIR TX650W - power supply - 650 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.01/ EPS12V 2.2
- 80 PLUS Certification
- 80 PLUS
- Localisation
- United Kingdom
- Input Voltage
- AC 90-264 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 650 Watt
- Input Connectors
- 1
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power , 8 x 15 pin Serial ATA power , 10 x 4 PIN internal power
- Cooling System
- 120 mm fan
- 15 cm x 14 cm x 8.6 cm
- 5-year warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 90-264 V
- Frequency Required
- 47 - 63 Hz
- Input Connectors
- 1
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 650 Watt
- 80 PLUS
- Cables Included
- Power cable kit , Power cable - external
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, dual ball bearing cooling fan, non-modular
- TUV, C-Tick, CISPR 22 Class B, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, CB, C-Tick Class B, FCC Part 15, FCC Part 2, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03
- Limited warranty - 5 years , Technical support - 5 years
- 15 cm
- 14 cm
- 8.6 cm
Customer reviews
Write a review for the Corsair TX650W 650 Watt PSU ATX here!
Nice PSU
Reviewed by lego. Review Posted 28/10/2008
The package is fancy. When all the connectors are unfolded, it looks like a huge octopus, all connectors you need plus four for PCI cards, connectors are very long and can reach almost anywhere in the case.
Overall
Ease of use
Value for money
I'm very pleased.
Reviewed by Cobus. Review Posted 02/10/2008
This is a very good quality PSU, the packaging looks great and it has more power connectors than I will ever need. And it's very quiet.
Overall
Ease of use
Value for money
Good quality PSU
Reviewed by Anonymous Review Posted 02/09/2008
This was my first PC build and so I wanted a stable PSU. Corsair is a great brand. 650w is enough to power my two Sapphire HD4850 graphics cards and there are plenty of connectors for the rest of my PC.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
