Corsair Obsidian Series 550D quiet mid-tower case: The strong, silent type.
The Obsidian Series™ 550D has been carefully engineered for noise reduction. The front and side panels are insulated with sound dampening material, and the hard drive trays and fans have soft silicon mounts to absorb vibration. The top and side panel vents are covered for noise reduction if you're not using them to install your own fans, and even the intakes are angled to reduce air noise.
The rigid, stamped steel and brushed aluminium case holds some remarkable technology that makes it easy to build great systems. There's built-in USB 3.0 support, and the drive trays work with 2.5" SSDs. The removable hard drive bays allow customization for extra-long graphics cards and maximizing airflow. And, the easy-access side panels come off at the touch of a button for easy upgrades or simply admiring your work.
- Insulated, sound dampened side and front panels
- Six tool-free hard drive trays with integral SSD support and soft silicon sound dampening
- Four tool-free optical drive bays
- Angled air intakes for reduced noise
- Covered vents for noise reduction if additional fans (not included) are not installed
- Front panel USB 3.0 connectors and audio connectors
- Cable routing cut-outs with rubber grommets
- Removable, reversible front panel
- One-button side panel removal for quick access
- Matte black interior
- Three 120mm fans
- Top panel is compatible with 240mm radiators for dual-radiator Hydro Series™ CPU coolers and liquid cooling systems
- Eight expansion slots for multi-GPU compatibility
- Dimensions: 20.9" x 8.7" x 19.5"
- Material: Brushed aluminum with steel structure
- Color: Black
- Model: CC-9011015-WW
- Drive Bays: (x4) 5.25" / (x6) 3.5"/2.5" Drive Caddies
- Cooling: (x2) 120mm Intake fans / (x1) 120mm Exhaust Fan
- Expansion Slots: 8
- Motherboard: ATX, mATX
- Front I/O: (x2) USB 3.0, (x1) IEEE 1394 Firewire, (x1) Headphone, (x1) Mic
- Power Supply: ATX (not included)
- Warranty: Two Years
Box Contents
- Corsair Obsidian Series 550D case
- Accessory kit
- Quick Start Guide
A revolutionary combination of noise reduction and cooling
Obsidian Series 550D is carefully engineered for noise reduction and sound isolation. But, it's not just about keeping things quiet - there's amazing cooling potential, lots of expansion flexibility, and the durability that Obsidian Series is renowned for. -
Superior airflow for high-performance PCs
Obsidian Series 550D comes with two front-mounted 120mm intake fans and one 120mm exhaust fan - more than enough for delivering the airflow required for a high-performance system. But if you're pushing past high performance and into the realm of extreme-performance overclocking, there's room for a lot more. The top panel provides room for two 120mm or 140mm fans, or a 240mm radiator for compatibility with Corsair Hydro Series CPU coolers and other liquid cooling systems. The side panel has mounting points for another two 120mm or 140mm fans for cooling multiple GPUs. In total, the 550D offers ten 120mm fan mounting points, six of which can also accommodate 140mm fans. -
The silent treatment
With many high-end PC cases, cooling is often provided without consideration for noise. Not so with the 550D: the front and side panels are fully lined with sound-damping material, and the top and side panels have their own sound-insulated vent covers to reduce noise leakage from unused fan mounting locations. The front air intakes are angled away from the front of the case for noise reduction, and the fans and drive bays use silicone mounts to reduce vibration noise. The result is a platform for building high-performance PCs you can live with. -
Smart features for serious builders
The extra touches like magnetically mounted dust filters and one-button side panel removal make building fun, and using a 550D-based system a rewarding experience. Expansion is easy, with eight expansion slots, six tool-free hard drive bays with removable caddies and integrated 2.5" SSD support, and four tool-free optical drive bays. The top drive cage can be removed to accommodate GPUs of up to 452mm in length. The diamond-cut brushed aluminum front panel houses two high-speed USB 3.0 connectors and audio ports. -
The Obsidian Series: designed by builders, for builders
World-class Obsidian Series cases are made from stamped steel and brushed aluminum, providing both outstanding durability and great looks. State-of-the-art features are engineered with the singular purpose of meeting the needs of professional builders, high-end system integrators, and performance enthusiasts. Builds are straightforward and efficient, and there's room for nearly any system configuration you can imagine.
- CORSAIR Obsidian Series 550D - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- I/O Connectors
- 2 x USB 3.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Screwless drive bays, front panel door
- Power Device
- No power supply (ATX)
- 22.1 cm x 53.1 cm x 49.5 cm
- 7.5 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 6
- Product Material
- Steel, brushed aluminium
- Cooling System
- 120 mm fan x 3 , 120/140 mm fan mount x 6 , 120 mm fan mount x 4 , 200 mm fan mount x 1
- CPU Cooler Max Height
- 180 mm
- Video Card Max Length
- 318 mm
- Power Supply Max Length
- 180 mm
- Expansion Bays
- 4 (total) / 4 (free) x front accessible - 5.25" , 6 (total) / 6 (free) x internal - 3.5"
- Expansion Slots
- 8 x Expansion Slot
- 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Power Device
- No power supply
- Specification Compliance
- ATX
- 22.1 cm
- 53.1 cm
- 49.5 cm
- 7.5 kg
- Limited warranty - 2 years
