The Obsidian 450D is the ideal blend of solid, refined good looks and high performance cooling. In front of the two AF140L intake fans is an easily removed aluminium mesh dust filter that provides extraordinary airflow directly to your graphics cards and CPU cooler. On top of the case is room for up to a 360mm radiator, a rarity in mid-towers.
Of course, it wouldn't be a Corsair case without well-known, easy-to-use features like tool-free drive mounts for SSDs and 3.5" drives, optical drives, and excellent cable routing. Whether you're looking for high airflow or potential for liquid cooling, the 450D has you covered.
- Generous expansion room for building high-performance systems.
- Beautiful brushed aluminium fascia with mesh cut-outs makes an elegant design statement.
- Full side panel window to view your components.
- Tool-free SSD, Hard Drive, and Optical Drive installation.
- Includes two AF140L intake fans, and a rear AF120L exhaust.
- Tool-free SSD cages hidden behind the motherboard tray.
- Designed for fast and straightforward builds.
- Radiator and fan compatibility compatibility: Top: 3 x 120mm or 2 x 140mm (360mm radiator), Front: 2 x 140mm or 2 x 120mm (2 x 140mm included) (280mm radiator), Bottom: 2 x 120mm (240mm radiator), Rear: 1 x 120mm (120mm included) (120mm radiator)
- Two USB 3.0 front panel connectors, plus headphone and microphone.
- Easily accessed front, top, and PSU dust filters.
- Excellent cable routing with rubber grommets for clean builds.
- Maximum CPU Cooler Height 165mm
- Maximum GPU Length 430mm
Box Contents
- Obsidian 450D High Airflow Mid-Tower Case
- Accessory and screw box
- Quick Start Guide
Dual intake fans with direct airflow path to GPUs
The custom-designed, Corsair-exclusive intake fans deliver effective airflow with less noise and turbulence. Air intake passes directly across your GPUs for efficient heat dissipation. -
Seven fan mounting points for high-airflow and water-cooling applications
If your high-performance system build requires high-performance cooling, the 450D is an ideal platform. The mounts support front, bottom and rear radiators for flexible water-cooling installation options, or fans for superior ventilation. -
Modular drive cage system with lateral SSD bays
Mounting the SSDs under the motherboard uses interior space efficiently and gets your solid-state storage out of the airflow path. The removable drive cages allow you to use only the space you need for your storage requirements. -
Black anodized brushed aluminum fascia
The elegant aluminum front fascia is an Obsidian Series hallmark. It's durable and resistant to scratches and fingerprints. -
Extra-large, flush-mount side window
The clear acrylic window lets you show off your work.
- CORSAIR Obsidian Series 450D - tower - extended ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- Black
- I/O Connectors
- 2 x USB 3.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX, Extended ATX
- System Cabinet Features
- Screwless drive bays, meshed front panel, aluminium front panel
- Power Device
- No power supply (ATX)
- 21 cm x 49.7 cm x 49.4 cm
- 7 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- Extended ATX
- Internal Bays Qty
- 5
- Front Accessible Bays Qty
- 2
- Black
- Cooling System
- Top: 120 mm fan mount x 3 , Bottom: 120 mm fan mount x 2 , Front: 140 mm fan x 2 , Rear: 120 mm fan x 1
- CPU Cooler Max Height
- 165 mm
- Video Card Max Length
- 430 mm
- Power Supply Max Length
- 200 mm
- Expansion Bays
- 2 (total) / 2 (free) x front accessible - 5.25" , 2 (total) / 2 (free) x internal - 2.5" , 3 (total) / 3 (free) x internal - 2.5" / 3.5" shared
- Expansion Slots
- 7
- 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Power Device
- No power supply
- Specification Compliance
- ATX
- 21 cm
- 49.7 cm
- 49.4 cm
- 7 kg
- Limited warranty - 2 years
